Cleaning OEM 19"s
Jan 9, 2010 | 03:31 PM
Hey guys, i am currently in the process of cleaning my rays forged 19" wheels. The wheels are in excellent condition other then the fact that on the inside, it looks like there is a lot of brake dust that has settled on the rim....almost looks as if someone sprayed paint from the outside of the rim. The outside of the rim is completely fine.
I decided to try and see what i could do if i used a little scrubber from Mr. Clean. It is a lightweight plastic type scrubber, the type you might use in the kitchen. i thought the inside of the wheels were powder coated so i figured it might be fine. i tried it out and it worked, but i had to do some more intense scrubbing then i thought.
Currently i am just using meguiars gold class carwash. i would use a wheel cleaner but i don't have one, and i honestly don't think that a wheel cleaner would get rid of this stuff
Anyways, so my question is, is it damaging my wheels to scrub? Is there a protective coating placed on the inside of the rim? i am only scrubbing the inside of the wheel, not the outside that shows.
Also, can i wax my rim with just a normal wax?
Reply 0
Jan 9, 2010 | 03:39 PM
use engine degreaser
nothing else will work wo breaking ur back
Reply 0
Jan 9, 2010 | 03:40 PM
there is a protective powdercoating on your oem rims. Mine is coming off in a few places, its not noticeable unless you 2 inches away starring at the spot. Just give the rims a good rubdown.
Reply 0
Jan 9, 2010 | 03:41 PM
Use soap and water or simple green. ONLY.
Reply 0
Jan 9, 2010 | 03:46 PM
go ahead & brk ur back
Reply 0
Jan 9, 2010 | 03:48 PM
also when u go to put new tires on - they will do more to ur rims then remove the clear coatings
Reply 0
Jan 9, 2010 | 03:55 PM
since we're on the subject - a little common sense goes a long way
important car parts??? engine bolts etc need correct careful handling
not so fragile parts??? tires rims bumpers go ahead do as u please cause someone else will do it for u
Reply 0
Jan 9, 2010 | 04:13 PM
^^ Mr. Glass Half Full
Reply 0
Jan 9, 2010 | 04:16 PM
SwivelHips
Not Half Empty???
What do you mean???
Reply 0
Jan 9, 2010 | 04:51 PM
I'm saying (a bit sarcastically) that your outlook is just a tad pessimistic today. I know as well as anyone that other people don't treat your stuff as well as you do, but IMO that's no reason not to take care of it yourself.
Reply 0
Jan 9, 2010 | 06:31 PM
some1 needs to teach infinitisport about repost, lol..3 comments in a row
Reply 0
Jan 9, 2010 | 06:55 PM
so yes or no, never really reached a conclusion. can i scrub away, or should i just soap and water it? i just bought some of meguiars hot wheel shine or whatever, doesn't seem to do much, especially not for 13 bucks.
Reply 0
Jan 9, 2010 | 07:02 PM
Quote: Use soap and water or simple green. ONLY.
You've been given the answer grasshopper!! You can use regular wax after cleaning but I suggest a sealant applied before the wax. It will provide longer lasting and stronger protection.
Reply 0
Jan 9, 2010 | 07:06 PM
so, how can i get this brake dust or whatever off the paint, is there anyway?
Reply 0
Jan 9, 2010 | 07:52 PM
powdercoat your rims gunmetal or black and call it a day
Reply 0
