why cant i fill my gas tank up all the way?
Old Jan 12, 2010 | 11:12 PM
TDTh3Boss's Avatar
my tank was pretty much empty and after about 5-6 gallons it shut off and no matter which way i turn the gas pump it would cut out as if the tank was full but it was not even half full
Old Jan 12, 2010 | 11:30 PM
gary c's Avatar
Give Infiniti a call, I'm sure there was a recall on this issue having to do with the shutter valve....that's the only reason to deal with Infiniti.
Gary
Old Jan 13, 2010 | 01:10 AM
the_sedan's Avatar
theres an updated shutter valve and fuel cut bracket to solve this issue.......i've got both done to my coupe
Old Jan 13, 2010 | 01:51 AM
cknight03's Avatar
Try Shell premium, only gas that doesn't cut off with me.
Old Jan 13, 2010 | 08:55 AM
bina12834's Avatar
cuts off with me everytime. guage only fills up to about 3/4
Old Jan 13, 2010 | 08:58 AM
Hi-TechG35's Avatar
Shutter valve problems. You will have to go back to Infiniti for this. I believe there is a TSB for this.
Old Apr 15, 2010 | 08:48 PM
RelliKg35's Avatar
i called infiniti about this today and they say shutter valve is 30 and labor is 120...is that right? im out of warranty so i guess i have to pay out of pocket or is this a recall?
Old Apr 15, 2010 | 08:59 PM
GSedan03's Avatar
i have the same problem. only allows me to pump about 3/4th full, but damn i really dont want to pay out of pocket for something that infiniti messed up on
Old Apr 15, 2010 | 09:41 PM
rimshaker's Avatar
Check out the service bulletin about "hard to fill fuel tank" here:
http://x.infinitihelp.com/forum/loca...d&pp=12&page=3
I assume since it's an official TSB, it won't cost anything at the dealer. Someone correct me if i'm wrong.
Old Apr 15, 2010 | 09:46 PM
thatoneguy's Avatar
Correct, TSBs apply even if you are out of warranty.
Old Apr 15, 2010 | 09:55 PM
jibberjabbers's Avatar
Is this a quick fix or should I expect a long waiting time?
Old Apr 15, 2010 | 10:08 PM
alfhasg35's Avatar
I just spoke to riverside infiniti and they told me that tsb's are only honored during warranty.. So if u are out of warranty u are s.o.l...!! Anyone else..??
Old Apr 15, 2010 | 11:30 PM
jutn35's Avatar
G35 Coupe
check my thread
edit*
https://g35driver.com/forums/g-spot/...weirdness.html
Old Apr 15, 2010 | 11:51 PM
Ig35's Avatar
i have the same problem and im out of the warranty period, gotta give the stealership a call about this.
Old Apr 16, 2010 | 01:20 AM
ryuhn's Avatar
Dude i have the same problem..
The pump starts clicking and i keep pressing and then gas overflows. get in the car turn it on and its only like 3/4 wtf?!?!
