G35 coupe 2005 compression rod bushing crack
Old Jan 13, 2010 | 05:32 PM
kgatlast's Avatar
Dealer wants to charge $420 US to repair. Is it something I can likely get done more cheaply? I'm in Las Vegas area.
Old Jan 13, 2010 | 05:57 PM
sammy_G's Avatar
Whiteline makes replacment bushings that will last much longer than the oem rubber piece included with the part for $400+
usually they're about $60 a pair... but you'll need to find a shop with a hydraulic press to get the bushing into the arm... good luck
Old Jan 13, 2010 | 07:31 PM
jibberjabbers's Avatar
This should also be a recall. It's obvious that the old version is prone to cracking.. Nissan is since "modified" the current compression rod / bushing..
This should be a free replacement. I mean, the G has way too many little issues.
Old Jan 13, 2010 | 08:27 PM
cknight03's Avatar
I have this as well, my mechanic couldn't find the part in the system though.
kinetek
Aug 3, 2015 04:25 PM
laksjd84
Jul 24, 2015 05:12 PM
cyrus32
Jul 18, 2015 06:22 PM
attarday
Jul 15, 2015 04:03 PM
LoSt180
Steering & Suspension
Jul 15, 2015 08:31 AM
