Plenum spacer in NJ - Do I need copper??
Old Jan 20, 2010 | 12:44 AM
GiantsFan280's Avatar
I read that if you live in cold weather areas and places where it snows a lot that you should get copper for the plenum spacer. I live in NJ. Whaddya think? Is it necessary or just go with the regular one? Temps do drop in the winter but not too low, and it doesn't snow all that much either. I really don't feel like dropping an extra 80 dollars if its unnecessary.
I'm about to make the purchase tomorrow! Already got my z tube and pop charger in, front strut bar is on the way. I freakin love the G
Old Jan 20, 2010 | 12:51 AM
tragedycat's Avatar
I'd get the copper. No fiddling with the gasket when weather cools down or warms up.
Old Jan 20, 2010 | 01:41 AM
If I don't get the copper I'll have to make adjustments for summer / winter?
Old Jan 20, 2010 | 09:24 AM
tragedycat's Avatar
Yes there is a coolant control valve that you need to adjust when temperatures get above or below a certain point, if you don't get the copper version. I think it's 40 degrees.
Old Jan 20, 2010 | 10:41 AM
NjMatteSedan's Avatar
^ that sucks, thats the first im hearing of this, i thought you just install and never had to touch it again
Old Jan 20, 2010 | 10:57 AM
gary c's Avatar
Get the Copper & Valve....minimul cost!
OMG....why would that suck, it requires no more than 2 minutes and a long screwdriver. You could get copper and the valve like I did then it only requires you to make a small adjustment summer/winter....get both well worth the $.
Gary
Old Jan 20, 2010 | 11:55 AM
^ where do you get the valve? And does it come in th instructions what you have to do with the screwdriver when the weather changes?
Old Jan 20, 2010 | 12:33 PM
thelarsky's Avatar
All sold by Motordyne...the valve is even offered separately on their site. The instructions are available on the site as well.
I run copper iso-thermal (no coolant control valve) spacer in North Jersey.
Old Jan 20, 2010 | 01:30 PM
CreativeDesignZ's Avatar
i live in NJ, bought the iso thermal (one with coolant control valve) and have yet to turn the valve on and have had zero problems all winter. Get the basic with the armid gasket and ull be fine. No problems with anything freezing up through all the storms and weather we've had
Old Jan 20, 2010 | 02:44 PM
XLR8_'s Avatar
OK GUYS IM SORRY, BUT I LIVE IN EL PASO TX IN THE SUMMER IT GETS VERY HOT... I WANNA GO WITH THE MD 5/16 Iso copper thermal spacer IS THIS OK OR IS THERE A BETTER ONE?? IM NEW TO ALL THIS MY BAD
Old Jan 20, 2010 | 03:42 PM
thelarsky's Avatar
There is no reason to spend the extra money on copper in TX since you will only need to adjust the valve twice per year. The copper is designed so you don't have to fool with the valve in climates where it could drop to near freezing more often during the year.
Check Tony's (Hydrazine) post in this thread for more info on the different types of spacer setups MD offers.
https://g35driver.com/forums/engine-...ml#post4824930
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
