car tried to start then died. finally worked but now engine service light is on
Old Jan 30, 2010 | 08:47 PM
sonsofliberty's Avatar
yesterday i drove to a deli two blocks away, parked, went in and got some stuff came out to the car and when i tried to start it the engine would turn over like normal. and usually you hear it start up with the exhaust note but (trying to explain this the best i can) it would like half start and just die out. it happened a couple of times before it finally started but then the engine service light came on and has been on since. i'm not too sure what's wrong with it does anyone have any ideas?
Old Jan 31, 2010 | 02:38 PM
bump..anyone got any ideas?
Old Jan 31, 2010 | 03:01 PM
thelarsky's Avatar
Well to start with, what's the OBDII code? Go to an auto parts store that will let you borrow a scanner if you don't have one...
Old Feb 2, 2010 | 06:02 PM
ballain's Avatar
Ok well it probebly means that when it died out, is ALMOST started, but just wasnt enough, so usually the second crank is gonna take a little longer because you have more gas to burn,
Now, if its not doing it anymore and it works fine, just drive it, usually if a code clears it the light should reset auto within a few days,
if not well you might wanna have a scanner hocked on
Old Feb 2, 2010 | 06:50 PM
^thanks alot for the info. after it happened it ran just fine. and ever since then everytime i start it it starts up just fine, no hesitation no nothing. tho that light is still on..i'm thinking about bringing it to the dealer i'm not very mechanically inclined..
Old Feb 2, 2010 | 08:03 PM
solobaric's Avatar
Something very similar happened to my car about 2 weeks ago. Turned out to be a faulty throttle body (covered by warranty).
Old Feb 2, 2010 | 08:11 PM
warranty is expired =[
Old Feb 2, 2010 | 08:15 PM
2QU1CK's Avatar
something similar happend, i drove it with the light on for about 80 miles and it reset itelf. drive it for a while regular, for like a week
chinee
Jun 10, 2024 07:48 PM
Mry
Mar 3, 2023 01:03 AM
ClwMike
Jul 23, 2015 12:55 PM
THMotorsports
Midwestern
Jul 22, 2015 10:27 AM
mjfenix
Jul 17, 2015 02:07 PM
