Transmission Flush @ Nissan.
Old Nov 3, 2010 | 11:38 PM
  #46
626Gthirtyfive's Avatar
Originally Posted by gary c
If you'll check your service manuals I believe Nissan requires a drain/fill every 30K miles and does not recommend doing a flush unless you're having trans shifting issues
Interesting. So is the transmission flush all a big misconception? I always thought flush>drain&fill.
Old Nov 18, 2010 | 11:59 AM
  #47
od2681's Avatar
I have an 03 G35 with about 97k miles on it. I bought it pre owned at 68k. Have no idea if previous owner did anything ot the car. I will be doing a tune up around 100k and thought I should do the drain and fill. Talked to dealer and they want 179 which includes tranny filter. I can probably do the drain and fill by myself (at a friends house) for lot cheaper than that. Just wondering if I should do tranny flush. When I asked the dealer if they were doing a flush and he adamantly said no. Sounded like Nissan doesnt want flushes?
Old Nov 18, 2010 | 12:14 PM
  #48
gtoor1990's Avatar
Im not sure for infiniti / nissan but for my 07 audi a6 quattro i got quoted 600+ for just the flush.. Its ridiculous
Old Nov 18, 2010 | 12:15 PM
  #49
Alex305's Avatar
Do i need a dran & refill my 05 AT just reached 80K miles and im not sure the previous owner did anything to it? Can any infinity dealer pull out record of maintenance if i give them my V.I.N number to see if it was flush & drain before?
Old Nov 18, 2010 | 03:24 PM
  #50
georgiadave's Avatar
The auto transmission does not have a filter. A drain and fill will take 3-4 quarts.
Old Nov 19, 2010 | 01:27 AM
  #51
SofaKingG's Avatar
OMG, did you ask them if you had "Stupid" written on your forehead? I had Nissan R&R ALL the fluids in my coupe and paid less than $300. Search an auto parts store that sells Red Line synthetic trans fluid and take that to AAMCO and have them change it. You'll be $ ahead and using the best fuilds available.
Gary
Gary have you used the RED LINE SYNTHETIC trans fluid in your car? I know that OEM is always the SAFE route. Thanks.
Old Nov 19, 2010 | 10:25 AM
  #52
R10T_x's Avatar
i paid 196.45 at infiniti of palm beach just got it done 3 days ago
Old Nov 19, 2010 | 10:45 AM
  #53
BlkCoupe's Avatar
You know guys it seems a little dumb to be concerned about a few hundred dollars when a new transmission will cost you $3,692 plus installation. It's not like you need a flush every six months. To me this seems like spend a little to save alot. Just my opinion and I have an 03 with 19,800 miles on it and I have had a flush and fill because fluids age.
Old Dec 2, 2010 | 08:24 PM
  #54
HIAG35SILVER's Avatar
where online can i buy matic s tranny oil and how much do i need ??new owner just got mines 2 days ago looking to change all the fluids
Old Dec 7, 2010 | 12:16 PM
  #55
Vectork39's Avatar
Infiniti of ramsey nj is running a special...259 plus tax. GET REAlL! any other lower cost options in NJ assuming i bring my own fluid?
05 sedan 5at
Old Dec 7, 2010 | 01:11 PM
  #56
saywat?'s Avatar
idk $250 sounds like a deal to me
Old Dec 7, 2010 | 09:54 PM
  #57
agedog2gt's Avatar
wow, any warranty? then again you are taking it to the dealer.
Old Dec 30, 2010 | 01:59 AM
  #58
gq916's Avatar
i got quoted $340 at infiniti and $245 from Nissan..both use S matic fluid. Infiniti guy said he would give me a 10% discount tho =)
Old Dec 30, 2010 | 01:20 PM
  #59
AuAltima3.5's Avatar
It is very simple to do a drain and fill. The hardest part is getting the car in the air.
You can do drain/fill with 4 qts of fluid and some time.
If you are more inclined, you can do your own version of a flush using bythabay's write-up and do the capacity or just a few quarts.
I can't handle paying more than 80 or 100 bucks for something so simple. I spent about 50 bucks on Matic-S and did about a 5 1/4 quart exchange. 220 is unreal. It takes about ten minutes if you're taking beer breaks.
I highly recommend looking at the FAQ page. It's full of ways to save a ton of money.
Old Mar 3, 2011 | 03:04 PM
  #60
DGP-G35's Avatar
Doing a Flush or a Drain & Fill depends upon the condition of the current fluid in the transmission (not just the mileage on the car). If the Fluid is still fairly clean and has proper viscosity then there is no need to do a flush, if the fluid has lost those characteristics and possibly has a bit different odor then it's time for a Flush (otherwise you are simply mixing about 1/3 new fluid with 2/3's worn fluid and within minutes the new fluid will be polluted by the old fluid).
This comes from somebody that was in automotive for 25 years.
Jason
