Cluth/trans issues
Old Feb 13, 2010 | 09:13 AM
Romanski85's Avatar
Cluth/trans issues
05 6spd coupe 42k miles 380hp.
I think my clutch may be going.. First gear is fine, however, when I shift into 2nd and hit the gas while completely off the clutch the car reves about a 1k before it finlly catches and starts to pull. I'm only at around 10-15% throtle.. Rpms seem to rev higher with more throtle being applied before catching..
Old Feb 13, 2010 | 09:52 AM
LordFappington's Avatar
If it slips its time to start looking for a replacement.
Old Feb 13, 2010 | 10:04 AM
Texasscout's Avatar
If it's a stock clutch and you are running close to 400 RWHP, yeah, it's time. Jim Wolf Technology has a great clutch pack for this for less than $800.
Look here: http://www.importpartspro.com/jwthdclco03i.html
Old Feb 13, 2010 | 10:07 AM
gary c's Avatar
That's....^....not a good sign, defiantly time for a new clutch! Where'd you get the extra HP from TT or Supercharger?
Gary
Old Feb 13, 2010 | 10:49 AM
Romanski85's Avatar
Thx for the replies guys. She's going in on monday.
It's Supercharged.
Old Feb 13, 2010 | 10:53 AM
Romanski85's Avatar
Also I'm taking off the short headers with the test pipes and going with the long tube headers from Megan racing. Heard good things about them. And I went back to the 2.5" dual exhaust from the 3" single exhaust.
Old Feb 13, 2010 | 01:19 PM
Texasscout's Avatar
Can you run cats with long tube headers or do they take up all the room?
Old Feb 13, 2010 | 01:43 PM
Romanski85's Avatar
The long tube headers will completely eliminate ur cats and bolt right to you Y-pipe or dual exhaust, which ever you have. They are a direct bolt so they will end right were your cats would thus no other modification is needed. What you will need to do is trick the computer so ur service light don't turn on. They have the trick system on eBay for $5 each or so. You will need 2 of them, one per each header. It's a simple screw in and ur done, 5min at most for the trick system install.
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
