rear end swaying!!!
Feb 15, 2010 | 06:40 PM
i had a bushing go out on my rear passenger side toe arm. originally that is what i thought was causing my rear end to sway side to side. i replace the toe arms with wicked tuning arms and get it aligned. the more i drive it the worse it seems the swaying gets. I've checked everything i could, all bolts are tight. any idea what it could be? its an 04 coupe with the sport package
Reply 0
Feb 15, 2010 | 07:47 PM
Do you have to elongate the bolt hole with those arms? The SPC and Ichiba arms need to have the bolt hole on the car elongated so the arm can be moved in towards the car. If you dont, you get quite a bit of sway. I didnt get any instructions with mine so drove 1 day with out grinding the hole, tons of slop.
Reply 0
Feb 15, 2010 | 08:13 PM
you sure the alignment was set to spec? tire wear?
Reply 0
Feb 16, 2010 | 05:55 PM
i have no idea what elongante the hole is. but it did this before i swapped the arms.
yea the alignment was near perfect.. or at least thats what the print out showed
Reply 0
Feb 16, 2010 | 05:59 PM
You need toe arms and camber arms.. adjustable.
Reply 0
Feb 16, 2010 | 06:27 PM
i got wicked toe arms their adjustable
Reply 0
Feb 16, 2010 | 06:28 PM
rear camber is fine
Reply 0
Feb 17, 2010 | 10:53 AM
Quote: rear camber is fine
Can we assume (dislike that word) since you were under your G you checked out the rear swaybar endlinks? I know a few members had the issue of them breaking. That would cause your rear end to get loose and sway....
Gary
Reply 0
Feb 17, 2010 | 01:37 PM
^^ i agree with gary. it's the swaybar endlinks. my car did the same thing as they were going bad.
Reply 0
