Hard shifts after tranny flush?
Old Feb 23, 2010 | 07:58 AM
IHIERBal's Avatar
Originally Posted by felixsc300
Does change mean a drain and refill or a flush? Jw, gonna bring the car in for service soon.
I would specify with the facility that you're at what they would exactly be doing. There's a big difference between flushing and draining/filling. You would technically be "changing" fluid with both so I'd ask just to be sure.
Old Feb 23, 2010 | 08:55 AM
miltoda's Avatar
The owner's manual states to inspect fluid every 30k, not change it. I go with the drain and fill philosophy. It's quick, it's easy, and I do it myself in the comfort of my garage.
Old Feb 24, 2010 | 01:59 AM
g35shadowchaser's Avatar
Originally Posted by cjr609
So what do you feel my options are? I'm taking it back on tomorrow to see what they can do, but the only reason I got it is because they kept strongly recommending it a numerous amount of times after I took it in for Oil Changes/Service Checkup's so in my fairness they kind of pushed it on me. Are the liable to fix this now? Or will I be **** out of luck?
Again, this is a touchy subject. Did they have you sign any form of waiver before the flush was performed. I would definately bring it back to them and express your concerns and definately have them double check the fluid level or better yet you check the fluid level. I know you said that they somewhat pushed you into it and here is where the difference between dealerships and smaller franchised oil lube facilities can be seen. I only own the one store and greatly value retaining my customers, so I tend to step to the plate if there is a chance an error has been made, they are probably not as willing to help you out. Good luck with them, hopefully its just a bit low on fluid!
Old Feb 27, 2010 | 08:18 PM
nissan_driver24's Avatar
When's the last time you the tranny fluid changed? Sounds like the fluid was never changed before and the flush caused the problem.
Old Feb 27, 2010 | 08:28 PM
officerdbag's Avatar
I havent changed mine in 54K.. I am slacking.. I have 75K on the car.
Im doing a drain and refill (4 quarts) and I'll let you guys know.
Old Feb 27, 2010 | 09:08 PM
gary c's Avatar
I would hope by today you've already taken you G back to Nissan and told them how your trans is shifting. With the right amount of trans fluid your tranny should be over joyed....bet they didn't fill it!
Gary
Old Apr 15, 2011 | 04:52 PM
VeRDE35's Avatar
Just had the same thing happen to me except I had a friend from Toyota do my service. Pretty worried as I just bought this car
Old Apr 15, 2011 | 05:00 PM
Swivel's Avatar
Moderator
Gary
This is all you should do to start. Tell them it was fine before, now it shifts badly, please diagnose and fix -- on their dime.
Picture Share
Feb 4, 2018 12:41 PM
MrIP35
Audio/Video/Electronics
Nov 8, 2015 10:47 AM
RWDguy4238
Sep 30, 2015 12:13 AM
blnewt
Sep 25, 2015 01:48 PM
