Need help with ABS
Old Feb 24, 2010 | 05:16 PM
TurK's Avatar
Thumbs down Need help with ABS
So with all the trouble I had with that SPC camber kit I decided to take the kit off. Yesterday I went to the shop that installed the kit and had the kit removed. The problems are still occurring. I'm having the lights and the horrible abs vibration and sound whenever I hit the breaks....
The shops solutions for me was to remove the kit and now they want me to go to the Nissan dealer to buy the brackets for the sensors since they had to bend them to try and make it work for the kit before.
Does anyone know where I can get these brackets for the sensors??
any other help to my problems? What do you guys suggest I do.
Thanks,
TurK
Old Feb 24, 2010 | 05:35 PM
JOKER's Avatar
CLUB MODERATOR
they had to bend sensors?
that sounds weird.
are you sure they did not mess them up?
Old Feb 28, 2010 | 12:41 AM
TurK's Avatar
I have a slight idea that they did.... Were they not supposed to bend the sensors?
Old Mar 1, 2010 | 08:22 PM
TurK's Avatar
any help?
Old Mar 1, 2010 | 08:47 PM
herrschaft's Avatar
No, the kit comes with little washers the are supposed to be used in order to align the sensors. I assuming they go behind the brackets but I didn't install them personally.
Old Mar 1, 2010 | 08:54 PM
herrschaft's Avatar
any help?
Call SPC and see if they can send you the spacers/washers if you don't already have them. It shouldn't cost much they'll fit in an envelope. Then take your car to a competent shop to re-install the kit. Inventory your kit just to confirm. I'm almost certain this is your issue.
Old Mar 1, 2010 | 09:13 PM
nghiars's Avatar
they shouldnt have had to touch the sensors for the kit to camber kit to fit. Rear camber kit correct?
Old Mar 1, 2010 | 09:18 PM
herrschaft's Avatar
^For the front they do
Thebaws11
Jul 2, 2021 11:36 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Thebaws11
Nov 30, 2016 12:54 PM
miata007
Aug 17, 2015 04:36 PM
