Help with thermostat for hot country G's
Old Feb 25, 2010 | 02:18 PM
0-60Motorsports's Avatar
Question Help with thermostat for hot country G's
Hello Guys n Gals,
I would like to say these forums are awesome! I recently became the proud owner of a STOCK 04 G35 Coupe, Red/Black, premium edition Auto
I was wondering if you all can give me some advice on water temps and tstats for the car in HOT countries.
In BAHRAIN the weather is very hot in summer, 120f easy with high humidity. My water temps sits at the half way mark (see attached pic), is this normal?
As my car is U.S. Spec i was wondering if it will benefit me using the MISHIMOTO Racing Thermostat. Maybe it'll be safer for my engine in the long run to use the Mishimoto racing tstat. My car has 94k miles on the clock.
Let me know what you all think. Cheers.
Attached Thumbnails Help with thermostat for hot country G's-25022010126.jpg
Old Feb 25, 2010 | 02:37 PM
gary c's Avatar
Thermostats are mostly the same, they either work or not! If you want to make your G run cooler get a quality larger volume aluminum radiator. With your kinda mileage on the clock you're probably due anyway. Our OE radiators have plastic side tank, when they decide to blow it gets very ugly. I've run as large as 3 core radiators in the past with big V8s living in CA. A 2 core aluminum unit should be more than adequate for your needs....
Gary
Old Feb 25, 2010 | 02:40 PM
Revo's Avatar
Mine always runs precisely in the middle too. I have an 04 6MT Black/Black with some minor bolt on mods.
I've driven my car in anything from 100*F weather down to 35* weather and it pretty much is always at the 1/2 way mark, so unless you ever climb more than a tick or two above the half way mark, you are fine.
If I understand lower temp activated thermostats are for cars that warm up very quickly due to high power mods, it doesn't help much if you drive in a hot environment, because once your thermostat is open, it's open.
If you have heat issues (and I would say you have heat issues only if your temp rises above the half way mark by a few ticks or more), then I'd suggest going to a more efficient radiator fluid, since OEM stuff generally doesn't perform the as well as some other stuff. A common stuff used in bikes is Engine Ice - but it is pretty expensive (like 20 for a half gallon). However, it does work well and if you have temp issues it should make a difference.
In extreme situations you can also get an aftermarket radiator.
All I all I think your car will be fine if it's mostly stock. The cars are tested from the factory to run in a variety of environments. I think people would be pretty pissed if their cars had issues once the outside temp reached a certain degree...
Old Feb 25, 2010 | 02:43 PM
I just bought two gallons of Nissan premixed coolant. I was thinking of adding 2 small bottles of REDLINE water wetter to this. What do you think?
Old Feb 25, 2010 | 04:12 PM
bjquinnIUmed's Avatar
Your engine is designed from the factory to run safely at a certain operating temp. The fact that it's 120 outside doesn't really affect the internal operating temp of the engine itself. An aftermarket t-stat may help lower your engine temps, but this does not imply that you'd get better reliability or longevity from the engine. As said before, it's designed to run that way from the factory. Your car appears to be operating within the proper temp range, so I wouldn't recommend replacing your factory t-stat.
Old Feb 25, 2010 | 04:16 PM
Roger that! I am going to flush the coolant and add water wetter to it. Hopefully that'll be good enough for the coming crazy hot summer.
Keep those comments coming fellas. I'll post pics of my car during the weekend and how it compares to my E46 M3.
Old Feb 25, 2010 | 09:12 PM
DosEquis's Avatar
i would just leave it alone if the stat is working. if the engine gets too hot, then thats why you have fans.
hrdwirk1
Oct 2, 2015 06:34 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jay123
Sep 28, 2015 08:42 PM
Jcruzg35
Sep 26, 2015 04:47 PM
