Who's annoyed of the one piece headlight unit?
Old Mar 7, 2010 | 03:35 AM
akoustic's Avatar
Hey folks,
What bugs me is the one piece headlight unit and there is one small bulb (the line going down by the edge) is out and apparently it's gonna be a pain in the **** to replace that one.
what gives?
Also one of the tab holding the light unit bolted on to the frame has broken off. wth... any tab repair kit available?
Old Mar 7, 2010 | 08:45 AM
scottfedm's Avatar
That line going down the edge is called the clearance strip. Just want to give you a heads up before people on this site crack on you. Its not tough replacing that bulb. You just gotta take off the front part of the fender liner. Jack the car up. Its one screw and a few trim clips. then you have easy access to the light.
Do you still have the plastic piece that broke off. Which one broke off? There is no repair kit if you dont have that piece. One tab doesn't generally affect the way the housing sits.
Old May 6, 2010 | 08:46 PM
or_G's Avatar
thanks for the info scott
Old May 6, 2010 | 09:34 PM
NachoCheese's Avatar
Some people take the wheel off for more room, but you can turn the wheel to the inside and be fine. One you get the fender liner out of the way, it's pretty cake to replace.
Old May 6, 2010 | 09:39 PM
or_G's Avatar
Could I access the ballast the same way?
Old May 6, 2010 | 10:09 PM
Yessir. I thought my driver side D2R bulbs went out. I was able to pull it out the same way as you would the clearance strip and and be good.
Old May 7, 2010 | 01:14 AM
or_G's Avatar
thanks. thought i'd have to remove the lip and everything.
Sepsis
Feb 12, 2020 02:05 PM
EnCr1pt3d
Jul 8, 2019 02:48 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
willdogs
Dec 8, 2015 11:32 AM
