Illuminated door sills anyone?
Old Oct 1, 2004 | 04:34 PM
  #31
Zen_S14's Avatar
Re: Illuminated door sills anyone?
Based upon my study of my Silvia light up doorsills, you only need the following to pull off what you guys are trying to accomplish.
Firstly, cut a long rectangular section out of the doorsill where you want the infiniti lightup symbol.
Replace that rectangular section with a piece of plexi or other see through hard plastic.
Get a decal made in rectangular section with the name infiniti and ask that the decal guy give you the surround not the actual decal cutout.
Stick said decal onto the rectangular section of the plastic so only light that can shine through the clear lense is the word infiniti.
Get this Flat light in the same size as the rectangular section and install it underneath the doorsill. http://www.beingseen.com/flatlite.htm
Hook up light to your interior light wiring.
There is your light up door sill.
The real hard part is to remove the aluminum from your doorsill to make the cutout. However, since your are not trying to cutout a name its still less work.
Old Oct 2, 2004 | 12:55 AM
  #32
GodZilla's Avatar
I was working on something similar on the Z's but stopped due to I found out that piece where the door sills are tends to fill up with water that could cause issues later with the set up..
Does the G do anything similar??
If not then I could possibly do them.
I had actually already made a complete piece stamped out of aluminum for them that could easily be converted..
Old Oct 18, 2004 | 10:42 PM
  #33
DeMoNWaReS's Avatar
I am very interested in this. I would like to know if someone made this possible.
I want to give it a go... can someone tell me where I can find and order new door sills? I tried www.infiniti-parts.com but that did not give a result
Old Oct 20, 2004 | 02:39 PM
  #34
DeMoNWaReS's Avatar
someone? Plz anser where I can buy new door sills?
Dallsinghjr1
Sep 17, 2023 11:25 AM
RA081024
Interior
Oct 27, 2015 07:27 PM
toadfire
Sep 21, 2015 07:15 AM
douglas555
Sep 10, 2015 04:48 PM
jbmw002
Sep 3, 2015 08:42 PM
