Is it going to cause big problem?
Old Mar 24, 2010 | 09:26 PM
colsoh's Avatar
Today, I cleaned the throttle body using the Sea Foam Deep Creep. While I had the butterfly valve open, I tried to spray the solution and the red plastic straw flew off inside the throttle body. I could not see or get this plastic straw out. So, I put everything back and drove around without any issue. Does anyone have any idea if this going to cause problems later on? Thanks for any advice.
Old Mar 24, 2010 | 09:27 PM
loki05's Avatar
^wth?!? isn't going to melt in there??
Old Mar 24, 2010 | 09:28 PM
JOKER's Avatar
CLUB MODERATOR
ARE YOU SERIOUS?
Oh Gaaaaaaaaaaaaaaawd!
Old Mar 24, 2010 | 09:30 PM
TofuProductions's Avatar
Old Mar 24, 2010 | 09:40 PM
JOKER's Avatar
CLUB MODERATOR
Old Mar 24, 2010 | 09:50 PM
DamnYankee's Avatar
Almost sounds like a setup for a joke. I hope it's not.
Old Mar 24, 2010 | 09:53 PM
VQ Johnny's Avatar
WTF pull your IM off and get that thing out of there, what is wrong with you, do you seriously think that's OK
colsoh's Avatar
No, this is not a joke. I am seriously looking for advices!
Old Mar 24, 2010 | 09:54 PM
dofu's Avatar
20 Year Member
It's probably stuck inside the intake plenum. Open it up by taking off the bolts up top and around and find out.
Dr. Ephil's Avatar
It's fine to leave it in there,wait and see if the engine blows up. It should be easy to reach it when rebuilding the block.
Old Mar 24, 2010 | 09:58 PM
DamnYankee's Avatar
You need to get it out dude.
Old Mar 24, 2010 | 09:59 PM
MJ-G35's Avatar
now come on....why would you even as if its going to be a problem?
Yea, it might hinder your motor a tad....I mean you might be new and all, but come on.
Old Mar 24, 2010 | 10:09 PM
gary c's Avatar
I don't think it's wise to leave that in your plenum, those straws are small and could end up anywhere. Take the time to pull the top off your plenum and get it out....shouldn't take an hour if you take your time.
Gary
Old Mar 24, 2010 | 10:26 PM
djjg35's Avatar
it would be best to get it the hell out of there! not a hard job!
Old Mar 24, 2010 | 10:32 PM
IHIERBal's Avatar
I concur.
