another will this wheel fit thread :(
Old Mar 30, 2010 | 05:39 PM
erklep's Avatar
Originally Posted by g35winnipeg
so instead o a spacer i could go for a 1-2" drop and not run spacers and i will sit flush?
thats cool, i never really knew that thanks for the info!
no, thats not what he meant. drop will tuck your wheels more. hes saying you can run spacers to get them to sit flush at your current height
Old Mar 30, 2010 | 05:42 PM
g35winnipeg's Avatar
ok maybe i will look into a 20mm spacer then all the way around for these
Old Mar 30, 2010 | 05:46 PM
4DGS's Avatar
Yea what I meant is the opposite, the lower you go the more your camber is going to pull the wheel towards the center of the car, meaning you will need lower offsets/bigger spacers to sit flush.
Old Mar 31, 2010 | 06:01 AM
Nightcrawler's Avatar
I recently put 18 x 9.5 +20 Nismo LMGT4 wheels on my V35 and thought they would sit too wide .... from the pics you can see quite the contrary. With the V lowered around 1.5 inches all round the fronts could do with 5-10mm more and the rears could do with 10-20mm more until I install the rear camber arms.
Old Mar 31, 2010 | 12:04 PM
VictoriousG's Avatar
Originally Posted by Jackus
no you need more than 25 to make it sit flush, and anything after 25 is not safe... soo get a wider wheel kthx.
I haven't heard of anything over 25mm won't be safe do you have proof?
Old Mar 31, 2010 | 12:17 PM
JBF's Avatar
JBF
can you justify how anything more than 25 is not safe?
cause I've been rockin 30mm for quite some time and have had no problems with track days, canyon runs, daily driving.
Old Mar 31, 2010 | 12:22 PM
nightcrawler those r sick wheels!!
Old Mar 31, 2010 | 12:49 PM
erklep's Avatar
+1 i would like to know as well. in theory, its really no different than running a wheel with lower offsets.
Old Mar 31, 2010 | 01:42 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
your in winnipeg, a drop will kill you if you drive winters.
edit: plus our streets are the worst around.
Old Mar 31, 2010 | 09:17 PM
the_sedan's Avatar
ive got 18x9/10 +20 lowered on tanabes and it looks good, not exactly flush which is why i'm putting 15mm spacers all around to get it closer
Old Apr 1, 2010 | 11:19 AM
bnorris85's Avatar
was going to make a similar thread, but decided to hijack yours instead
03 coupe stock ride height brembos
volk gts's
Specs are F 19x9.5 +17 offset with a Kumho Ecsta 245/35/19 tire and R 19x10.5 +18 offset with a Kumho Ecsta 285/35/19 tire.
reavensf
Sep 17, 2015 11:30 PM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
