my steering wheel is shaky after spring installation :l
Old Apr 16, 2010 | 11:17 AM
  #31
gary c's Avatar
Originally Posted by drifts500
Brake could cause it too. Do not car wash when the brake is hot. Make sure it cools down...if not, the rotor will be bent cuz of water...and cause shaky steering wheel
(I have 350z s-tech on my car without alignment still...
Tire is fine...I need a good alignment shop!...)
Rotors don't become bent because of water, it starts in the poor quality forging process and gets worse when they over tighten your wheels with a impact gun. Our wheels should always be installed with a torq wrench, that eliminates most of the problem. Bent rotors can normally be felt when applying the brakes, higher the speed the worse the reaction/shake. If you'e lowered on Tein S-Techs without suspension adjusters and alignment you only think your tires are fine....look again!
Gary
Old Apr 16, 2010 | 01:11 PM
  #32
potmilkz's Avatar
its 95% your alingment
Old Apr 16, 2010 | 10:58 PM
  #33
B_Lam's Avatar
Maybe it's your spacers installed incorrectly? or not tight enough?
Luisgalvan33
Jul 19, 2018 08:16 PM
rping
Jul 26, 2015 09:53 PM
Karnicle
Jul 23, 2015 05:08 AM
