Best plenum spacer??
Old Apr 20, 2010 | 04:30 PM
dofu's Avatar
20 Year Member
Originally Posted by BuckeyeInMI
What's kinda pointless? I'm aware that copper has a fairly low thermal mass and high thermal conductivity, but that heat's gotta go somewhere, and where it goes is the throttle body. I'd say at best, your TB temp will be the same as ambient, but only when the ambient is already pretty high (which you agree with). At worst, your TB temp will be much higher than ambient, and that's not an optimal setup. There's pretty much no scenario with ambient temps above 50 where you're better off having a heated TB. In fact, with ambients between 50 and 85 or so, you're worse off having a heated TB, so why not put in a CCV? The only time a heated TB is better is when it's below 45-50 or above maybe 120, but then it's actually cooling the TB, and at 120, you've got bigger problems than what your intake temps are.
You may think it's pointless, but the combination I described is a better setup than either of the upgrade options they offer. Besides, we're talking about a CCV that costs maybe $7-$8 in parts to build yourself.
Then what's the point of having the copper plating in your throttle body? The whole point is to eliminate heat from the coolant on warmer days, but still have the coolant flowing through to heat up the throttle body on cold days. If you must be able to control it to know it's working, then you might as well use just the valve and save some money because you're not going to utilize the copper plating for anything anymore. Water carries more and transfers heat better for colder days anyways.
Old Apr 21, 2010 | 01:20 AM
BuckeyeInMI's Avatar
Originally Posted by gary c
I could have sworn that's what I said....isn't separating it from heat and allowing it to stay cool the same thing? I've had my CCV for 4 years in the off position, those of us that live in warm climates don't need the extra heat since our G35s love cool temps/air....
Gary
We're not disagreeing on this, I think you were referring to the Aramid gasket when you said the copper isolates the plenum from the engine heat. It's the Aramid that does this. The copper ISO keeps the plenum from the heat sent to the throttle body, not the engine block.
Old Apr 21, 2010 | 01:27 AM
The point of having the copper plating between the TB and the plenum is so that the plenum stays cool in cooler weather, but the TB gets heated to keep the butterfly valve from freezing up.
CCV Only: Pros - unheated TB and plenum in warm weather, heated TB in cold weather. Cons - heated plenum in cold weather.
Cu ISO Only: Pros - heated TB and unheated plenum in cold weather, unheated plenum in warm weather. Cons - heated TB in warm weather.
Combining them gets you all the Pros and none of the Cons, i.e. everything unheated in warm weather, and only the TB heated in cold weather. I'm not saying which setup is the best setup for the money, I'm merely describing the best setup, and that's to have both the CCV and the Copper ISO unit.
Old Apr 21, 2010 | 01:35 AM
dofu's Avatar
20 Year Member
What pros and cons?
I still don't see the point in having both... The coolant isn't bringing that much heat to the throttle body that we need to be so paranoid about the heat being transferred from the water to the copper to the throttle body, but you're going to shut that down when temps get warm anyways, and the aramid gasket is already keeping the plenum cool so there's already a very minimal amount of heat being transfered to the throttle body from there. Either way, keeping the throttle body that much cooler than the plenum isn't going to help lower air intake temps anyways. And keeping the coolant valves the way it is would keep the butterfly valve from freezing better than this would with a copper plate there, so why do you need the copper plate again?
The whole point of having the copper plate is so you can get the best of both worlds.
Old Apr 21, 2010 | 02:14 AM
Well, I can't say it any clearer. You asked what pros and cons ^^, and I've already clearly laid them out. If you don't understand them, then I can't help you. Having the copper plate is NOT the best of both worlds because in warm weather it continues to heat the TB while the CCV doesn't.
And I never said it was some earth-shattering difference in the amount of heat, I just said it's a better setup, and so far you haven't shown that I'm wrong. The best setup for warm weather is a CCV because nothing is heated. The best setup for cold weather is the Copper ISO because only the TB is heated. Combining them allows you to have the best setup for warm and cold weather.
And I'm not being paranoid, I'm just pointing out the facts. We'll just have to agree to disagree.
Old Apr 28, 2011 | 12:35 AM
Sal Totino's Avatar
I got an 04 coupe manual transmission.. i live in NY ..best plenum for me? 5/16ths or 1/2 ?
Old Apr 28, 2011 | 01:58 AM
mistuhlayzee's Avatar
that depends which do you want more, low to mid power, or mid to high power
Old Apr 28, 2011 | 07:49 AM
Sal Totino's Avatar
well either or for now.. just so i get an idea of what to look into.. what is each one for
Old Apr 28, 2011 | 10:12 AM
mkonchel's Avatar
im taking it that 5/16 is better for low to mid range?
Old Apr 28, 2011 | 10:19 AM
gary c's Avatar
No doubt, hands down the very best that comes with everything you need for install plus detailed instructions is MotorDyne....did I make my point?
Gary
Old Apr 28, 2011 | 10:39 AM
Yea, the 5/16 is like the best of both worlds, from what i gathered from my research a while back, the 5/16 is for more city driving, while the 1/2 is more for the track and freeway.
Old Apr 28, 2011 | 11:12 AM
Sal Totino's Avatar
so im goin with the 5/16ths then.. they have like 5 different kits though
Old Apr 28, 2011 | 12:25 PM
Silencer_0's Avatar
Since it snows in NY, get the copper kit.
Old Apr 28, 2011 | 01:58 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
Copper Iso 5/16 inch from MotorDyne, many of the vendors in our marketplace carry it.
Old Apr 28, 2011 | 05:43 PM
  #30
grovefromnh's Avatar
I installed the Skunk 2 phanolic plastic 1/2" spacer with silicone gaskets. I chose not to bypass the TB. I also installed a Mototdyne lower plenum at the same time. Seat of the pants dyno felt a real improvement in mid range torque.
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
prinny
Nov 22, 2015 11:07 PM
w4kj4k
Oct 2, 2015 07:57 PM
thechitoguy
Oct 1, 2015 05:25 PM
BradMD_96
Intake & Exhaust
Sep 28, 2015 06:25 PM
