No license plate lights.
Old May 24, 2010 | 07:43 PM
kapowyadao's Avatar
I've changed the bulbs and checked all the fuses(concerning lights and lamps)on my 04 G35 coupe and still no license plate lights.
Old May 24, 2010 | 07:51 PM
dyzfoo's Avatar
if your not sure call the nearest infiniti dealer, they should know
Old May 24, 2010 | 08:26 PM
scottfedm's Avatar
Make sure the harness is plugged in behind the rear bumper. I actually had the same problem yesterday and found that the harness somehow shook loose.
Old May 25, 2010 | 03:24 AM
G35_REDLINE's Avatar
did u switch the bulbs around, like + to - and - to +, if that doesnt work then i dont know
Old May 25, 2010 | 03:53 PM
kapowyadao's Avatar
How do you get to the harness behind the bumper?
Old May 25, 2010 | 03:58 PM
kapowyadao's Avatar
Can you tell me how to locate and get to the harness?
Old May 25, 2010 | 09:31 PM
sillyoldtayo's Avatar
x2 on that note. When I replaced my bulbs with LED's they didnt work and I switched them around and VOILA!
Old May 26, 2010 | 01:13 AM
laksjd84's Avatar
^leds you have to mess with + and - but not oem glass bulbs..assuming that his bulbs are stocks.
I say +1 on wiring behind comin lose.
Old May 26, 2010 | 01:19 AM
elayman's Avatar
to get to the harness look up in the gap of your rear bumper above your license plate and you'll see 2 little plastic housings, on one side of each of them it's a bit longer and you sort of push it towards the lens and it should pop down.. sorry kind of hard to explain
Old May 26, 2010 | 10:07 AM
scottfedm's Avatar
i think it would be the main harness that connects to the splitter. Its a PIA to reach but its an simple problem. If you look underneath the bumper you can see the metal housing that the lights clip into. those lights are plugged into a 2 to 1 harness (it looks like a Y). You want to look for the main clip.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
vamarris
Sep 26, 2015 12:56 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
bigmike
Sep 17, 2015 01:58 PM
