Check Engine Oil
Check Engine Oil
Hey everyone,
I have a 2007 G35x Sedan.. I got an oil change last week (not at the dealer) and on the way to work this morning the "Check Engine Oil" message came on the information area near my speedometer.
Does that mean the place probably didnt actually change my oil? Is there anything else that could cause this?
At first i thought it was just my generic maintenance reminder that i forgot to reset or something.. then i realized it specifically said oil with the maintenance reminders dont do.
Thanks for your advice!
i didnt check anything.. it came on just as i was getting to work. i dont know much about cars either. i didnt see any oil leaking but ill check my parking spot when i leave today.i called the place i got it done and they said to bring it in and theyd take a look at it :[
if theyre' the culprit, im kind of scared to go there...
will do!
it doesn't matter if it hasn't leaked if they didn't put enough in the first place. Just check the oil level.
I guess you don't know much about cars
when you see that warning on your dash you should be pulling your dipstick....that's the yellow thing under your hood and check the oil level. If your smoke alarm went off wouldn't you be looking for the cause?
Gary
when you see that warning on your dash you should be pulling your dipstick....that's the yellow thing under your hood and check the oil level. If your smoke alarm went off wouldn't you be looking for the cause?Gary
wow dude just listen to others. and check yoru dam oil level. **** stop being so dam lazy. if you DONT have any oil in your engine it can be ****ed.
if there is oil in the engine your engine can still be ****ed. but we won't know anything until you eliminate some stuff first. there's so much stuff that can trigger that light.
If you have been driving the car with that light on your engine is probably f***, when it came on u should of immediately stopped and check the oil level on the dipstick THIS IS AS BASIC AS IT GETS every man should know how to do this! Pop the hoop and take the stick out and look if its low... Dont Drive the car! Hope u still under warranty Good Luck
Ok are you talking about the "Oil" light that takes up your whole little screen on your dash? or the tiny icon?
If its the bigger one they just forgot to reset the maintenance reminder. There are like 3 different types of maintenance reminders.... my mechanic sets it to 5000 miles so when it comes on (huge pic of oil thingy) I just take it in.
my last two cars were camry's and they were pretty much maintenance-less. I guess i never learned the basics.
yes! thats the one. it took up the whole screen. i get oil changes pretty often so i had not ever seen that indicator before.. which is why it was alarming to me.
thanks for everyones help!
checking the oil is the same process whether you drive a kia or a porsche.
i realize that, but i never had the indicator for oil problems come on. I used to get oil changes every 3000 miles.. and the car probably didnt have any many sensors/reminders.
Gary
