CAI and WaterSoak....
Old Jun 19, 2010 | 08:30 AM
CheechCaliss's Avatar
Question CAI and WaterSoak....
is that possible to soak water from rain with CAI or just a myth ?
Old Jun 19, 2010 | 09:55 AM
rajun asian's Avatar
I know it was a good possibility when had an AEM V2 in my S2k because the filter was so low in the bumper. The filter was also angled up so water could collect in the elbow and there have been cases of hydro lock. I'm still learning about the G so I can't help you there but in the S, it was possible.
Old Jun 19, 2010 | 11:19 AM
herrschaft's Avatar
If you inner fender linings are there then the filter will not get soaked. All you have to worry about is deep puddles and heat soak.
Old Jun 19, 2010 | 11:57 AM
gmotion04's Avatar
do u live somewhere in low lying areas that are prone to flooding if so you might worry but i wouldn't worry unless your someone who likes to ford rivers i wouldnt worry get a hydroshield if your that worried i had a cai on my rsx and never had a problem and i had to go through some puddles
Old Jun 19, 2010 | 12:03 PM
gary c's Avatar
Ingesting that much water into your intake is possible if the filter sits very low which might result in hydro lock. Filter company's have bags that fit over the filters to keep this from happening, do they work....doono. To me it's not worth have the intake filter sitting in harms way, for what purpose? Intakes where the filter sits close to the OE position won't have water issues unless you're in a flood up over the fenders!
Gary
Old Jun 19, 2010 | 01:43 PM
the_sedan's Avatar
just dont go driving through flooded areas and you wont have a problem. my filter sits right about....under my headlight so its not to the bottom.
Old Jun 19, 2010 | 01:49 PM
SDGenius's Avatar
all you need to do is add a bypass into the tubing and you won't not be able to intake any water.>>> http://www.aemintakes.com/air_bypass_valve.htm
Old Jun 19, 2010 | 02:07 PM
jibberjabbers's Avatar
The bypass valve is just a stupid filter. So your basically taking in a bit of warm air if you have that installed.
The OEM intake is already a cold air intake. So leave it alone. Why would you want to install a long azz pipe anyways. Shorter intake = shorter distance for the air to travel.
Old Jun 19, 2010 | 02:10 PM
SDGenius's Avatar
^he already has a CAI, he was asking about hydro-lock NOT CAI vs OEM
Old Jun 19, 2010 | 03:13 PM
so for now, I'll TANX U ALL i have remove my CAI to Short Ram, injen got both...
now i'm worried about heat pushed away by the front fans and get sucked by my filter. Anyways should be better hot air than water ...tank u guys.
TrillO.G.35
Sep 5, 2015 02:06 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
EPG35
Aug 16, 2015 04:52 PM
Racova
2nd Gen (V36) Sedan
Aug 8, 2015 10:21 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
