My specs after alignment-your thoughts...
Old Jun 28, 2010 | 07:17 PM
CLEANBS's Avatar
I told them to get my toe as close to 0 as possible to help with front feathering.
OEM Suspension, OEM 18s
http://i45.tinypic.com/167tflu.jpg
Also does my rear camber look off?
Old Jun 28, 2010 | 08:25 PM
CLEANBS's Avatar
It looks like they didnt even do anything to the rear
Old Jun 28, 2010 | 09:13 PM
bjquinnIUmed's Avatar
Why did you get the alignment to begin with?
Everything looks good except for the rear camber, and that's not that far off. As long as your toe is in spec, that's gonna be the majority of your tire wear. Not sure with an OEM setup why your camber falls out of spec though. I'd be kinda upset about paying for no adjustment.
Old Jun 28, 2010 | 09:25 PM
CLEANBS's Avatar
I got one because its been a year and 20,000 miles since I got one, and I just got new tires.
Should I go back and fix the rear camber? if so, what spec should I tell them to set it at
Old Jun 28, 2010 | 10:32 PM
Dave160's Avatar
^Are you lowered on anything without camber kits? If not then they should have no problem getting you back to OEM specs.
Old Jun 28, 2010 | 10:54 PM
EnJoiLuv's Avatar
Go back and tell em to actually do work on your car. It's like they just took the measurements and just left it alone after...
Old Jun 28, 2010 | 11:04 PM
CLEANBS's Avatar
yea I am, it looks like all they did was lower the front toe
Old Jun 29, 2010 | 02:19 AM
Xet's Avatar
Xet
No adjustments at all on the rears? They just stole your money and did nothing but barely touch the toe... I'm guessing you are stock suspension, if so tell them to put you full back in spec since you paid for the alignment!
But your car looks like it was fine before your alignment even and an alignment wasn't even really needed.
Old Jun 29, 2010 | 06:24 PM
CLEANBS's Avatar
Turned out the guy that initially did my alignment wasnt their main alignment guy. Just got it done by the main guy.
http://i46.tinypic.com/11aid21.jpg
Much better!
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Picture Share
Feb 4, 2018 12:41 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
