Clutch engagement is horrible!
Old Jul 14, 2010 | 10:41 AM
  #31
pythonjosh's Avatar
If you are making the SLIP sensor go off (the slip light flashes on your dash) then that is your VDC being activated/used.
Happens to me sometimes when going into gear at high rpm's.
If this is what you are complaining about, then turning it off will help, but if it's not, then it's not.
Old Jul 15, 2010 | 08:06 AM
  #32
M302_Imola's Avatar
Yeah can't be the VDC as the light doesn't illuminate and I'm keeping the RPM's low. So your right, doubt turning the VDC off is going to help.
Old Jul 15, 2010 | 07:08 PM
  #33
tEh d0ct0r's Avatar
Its not VDC thats the problem, thats for sure. I'm talking about shifting from first to second and the car jerking if engine speed is not exactly right when you let the clutch out.
Old Jul 15, 2010 | 10:22 PM
  #34
VQ Johnny's Avatar
Check this out, I came across it this morning and it sounds interesting. Its for the 2nd gen but I took a quick look at my 04 pedal this morning and there is the same spring in a different location. The jist of it is by removing the spring you feel the pressure plate instead of the spring making for a progressive pedal feel if that makes sense. I quickly read through it and people say once they get use to it the jerkyness is eliminated.
https://g35driver.com/forums/v36-diy...t-feeling.html
Old Jul 16, 2010 | 07:49 AM
  #35
M302_Imola's Avatar
Yep I believe you hit the nail on the head...this is exactly what I'm talking about. Guess I need to practice more on gettting the engine speed right during this 1st to 2nd gear shift. I guess my M3 has spoiled me as I don't have to worry about this jerking in any gear.
I will check that out...thanks!
Old Jul 16, 2010 | 05:57 PM
  #36
ThickG's Avatar
I believe this is only for the 2nd gen sedans. The coupes have a different setup.
RyanRebel54
Drivetrain
Oct 11, 2017 11:45 PM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
mattdg35
Sep 14, 2015 11:28 AM
