Evaluation of the First Four Mods To My G
Old Jul 14, 2010 | 07:52 AM
dofu's Avatar
20 Year Member
Originally Posted by gary c
Yes....really! Sierrahpbt used the word significant in reference to how sways would improve the ability of his G35. I was lucky enough to have Stillen install my sways at their open house a few years ago and didn't notice a great deal of difference and I'm always play'in in the canyons. It wasn't until I installed the upper strut bar/springs/shocks and endlinks did I notice a significant change in my cornering ability and that's always running Michelins on my coupe.
Gary
OK, granted... the stock shocks do suck that much. Even the sport suspension feels way too mushy for my taste, and I tend to forget that not everyone even had those from the factory! What settings are your sway bars at?
Old Jul 14, 2010 | 07:54 AM
sierrahpbt's Avatar
What gaping hole are you talking about with the R2C? The cutout your snorkel should fit in? I bought the 350Z version that doesn't have the cutout because I don't run the snorkel. I did have to fab a bracket to hold the box tight so it seals against the hood since my intake tube isn't supported at the plenum like most are. You can see my bracket coming off the radiator support to the left side of the box in the pic.
Great write up BTW!!
I should have gotten the 350Z version because the snorkel is several inches away from meeting up with the housing. I used metal strapping to connect the bracket to the tube. I must have done something very wrong but now I have the distinction of having the worst looking intake setup around.
Old Jul 14, 2010 | 09:49 AM
Tikiman12's Avatar
Originally Posted by sierrahpbt
The ground wires came from sxexcx and yes, the kit came with instructions which I read four times before starting the install. Not sure what you mean about installing the wires separately or all at once. Several of them share a common connection point. The complete job took one hour.
Sorry I should have been clearer. I wanted to know if you installed each mod seperatly, z-tube on stock car, then intake on stock car no ztube, spacer with stock intake system.
B/c you said each gave a noticable intake growl, I was just wondering if the growl was from a full install or for each piece by it self.
thanks
Old Jul 14, 2010 | 09:54 AM
dofu's Avatar
20 Year Member
thanks
You can hear your intake working a bit more with the Z-tube, but you can really hear the intake sucking in air after you swap out the box, sounding almost like a turbo spooling up. I don't think the spacer is going to make a huge difference on intake sound, at least I never noticed anything. But your car should sound just a bit more aggressive because it's getting better air flow into the motor altogether.
Old Jul 14, 2010 | 12:00 PM
Tikiman12's Avatar
o ok thanks, good to know
Old Jul 14, 2010 | 12:46 PM
sierrahpbt's Avatar
thanks
Communication is everything, know what i mean?
I installed each mod separately (a few days apart) but one on top of the other and I was able to judge each one on its own merits and also as a group mod. Hope that makes sense.
Old Jul 14, 2010 | 01:14 PM
Tikiman12's Avatar
cool thanks just what i wanted to know
Old Jul 14, 2010 | 05:15 PM
walshtj's Avatar
where did you get the grounding kit? Did it come with writen instructions on where the grounds are?
Did you install each of these seperately or all at once?
PM sean, SxExCx, has grounding kits with instructions. There is also a diy of making your own somewhere.
Old Jul 14, 2010 | 06:03 PM
sierrahpbt's Avatar
Well now I'm torn. I can do one more mod and then I need to slow the spending for a while. I need opinions please - would you get sways or HFCs next? They both sound worthwhile from what I am reading.
Old Jul 14, 2010 | 06:07 PM
Swivel's Avatar
Moderator
Since you've already done a couple of sound/performance mods, I'd go with the sways for some handling. Very effective mod, IMO.
Old Jul 14, 2010 | 06:28 PM
kennymo's Avatar
Sways
Old Jul 14, 2010 | 06:42 PM
Silencer_0's Avatar
Originally Posted by swivelhips
since you've already done a couple of sound/performance mods, i'd go with the sways for some handling. Very effective mod, imo.
+1.
Charchar66
Dec 19, 2019 01:17 PM
Video Share
Jan 31, 2017 04:00 PM
g.spot
May 9, 2016 10:54 PM
prinny
Nov 22, 2015 11:07 PM
RWDguy4238
Sep 30, 2015 12:13 AM
