Wheel & Tire guys, need your help!
Old Jul 22, 2010 | 09:06 PM
guidoguy's Avatar
I have a 2006 Coupe. I'm looking at some rear wheels that are size 19x10.5.
offset is +27. I'll be running a 275/35/19. Does anybody know if I'll have any rubbing issues with that offset? Will these wheels fit with that offset and width?
Old Jul 22, 2010 | 09:07 PM
guidoguy's Avatar
I'm running the same wheel size now but with a +22. If I go to a +27 does the wheel move out 5mm or in 5mm? Thanks for your input guys...
Old Jul 22, 2010 | 09:15 PM
whoozyadaddy7's Avatar
I'll try to answer before some people think about flaming you... Gonna be more tucked man. +27 is a fairly weak offset.
Oh and not even close to rubbing btw. PLENTY of room.
Old Jul 22, 2010 | 09:22 PM
NachoCheese's Avatar
I am running 275 on a 9.5" wheel and I have about 5mm or less of clearance between my tire and the inner rear fender lip (lowered on Tanabe DF210s). Are you lowered? If stock height, you'll be fine
Old Jul 22, 2010 | 09:51 PM
guidoguy's Avatar
Nachocheese, I'm lowered about 1/2 inch..., what offset are you running? I'm more concerend with a +27 offset and 10.5 wide wheel that the inside of the wheel will be rubbing on the actual shock absorber..
Old Jul 22, 2010 | 10:17 PM
guidoguy's Avatar
I'm looking to buy the TSW Nurburgring wheel and the only 19x10.5 they have is with a +27 offset. This is why i'm asking...
Old Jul 22, 2010 | 10:35 PM
You shouldnt rub the inside at all. My offsets are +20 in the rear
Old Jul 22, 2010 | 10:40 PM
Lone Wolf's Avatar
+1..u won't rub at all..I am only dropped a half inch in the rear..I am running a 10.5 by +21 no rubbing issues at all..with a 275/35/19
Old Jul 23, 2010 | 01:43 AM
jef_gutjr's Avatar
You should be good. I think you can even go with 285/35 on those and it would not rub.
Old Jul 23, 2010 | 11:00 AM
gary c's Avatar
If that's the only offset they offer with this wheel pass and find a wheel that fits better. With a 10.5" rim you can go with a mid/lower 20" offset and still run the 275s on a coupe. The 27 offset is way too high keep shopping!
Gary
bTanz
Oct 15, 2015 02:31 PM
Big C
19 Inch
11
Oct 3, 2015 05:11 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
