finally fixed the stupid vdc slip abs lights
Old Aug 18, 2010 | 06:54 PM
fatlip's Avatar
Went to the dealer to get the airbag recall checked out and they said its the reason the lights keep coming on. Well see what happens when they get the airbag module sorted.
Old Aug 18, 2010 | 10:28 PM
EF21's Avatar
My lights came on sunday for 25 miles i was scared and babied her home. I turn her off took the key of ignition took a breath and turn on the car it went away. Now after reading post i think ill change my pads which have plenty of life left even though they are the oem ones that came with this 05.
I hardly use brakes.
Old Nov 10, 2019 | 05:31 PM
Mark Morelli's Avatar
Basic
Originally Posted by Sammy23
I had the VDC light, brake light, and air bag light on...changed both rear wheel bearings and it went away...do u hear vibration or feel it
I have vibration what is it
Old Nov 25, 2019 | 05:11 PM
shurur's Avatar
2003 G35 Coupe
I had the brake switch push through the brake pedal during hard braking. The switch plunger pushed through the plastic/rubber pad on the brake pedal arm.
I replaced the pad with an pushpin and didnt get the light anymore.
may not be related..dunno..
Old Aug 14, 2024 | 03:12 PM
Argonaut's Avatar
G35X
Hi All,
First, let me thank all of you for sharing your experiences with these 3 lights, as it saved me from getting a new car. On July 30th, 2024, I took my G35X to a local mechanic after both the VDC, Slip, and ABS lights ALL came on at the same time. Also, the car drastically lost power, which I imagine is some type of "limp mode" for safety/function. By August 13th, the mechanic was 85% sure that the Codes he was reading were transmission related, but also wanted to check the mass air flow sensor and throttle body. As you could imagine, they had my car for 2 weeks, and given they had no answers other than they thought it was 85% the transmission, I showed up and got my keys to drive my car home. However, the battery was dead, so after I had the mechanic jump me off, I drove the car home in Limp Mode and was saying my goodbyes...ready to donate it or sell it for $500 on Craigslist. When I got home, I let the car run to charge the battery, and when I came out to turn the car off, I happened to walk around the back of the car and noticed my BRAKE LIGHTS were on. I couldn't figure out why...until I learned about brake light switches from some of you. This explained why the battery was dead, and sent me down the road to change the brake light switch in hopes of a miracle. While I was down there, I noticed the switch plunger was sticking through a hole...which I thought was odd...but proceeded to buy a new switch and replace it. However, after replacing the switch, the brake lights were still on, and I learned it wasn't the switch: it was the missing plastic pieces that sit in those holes to give the plunger something to rest on. I happened to look on the floorboard and found small pieces of broken plastic that would fit in that hole. I found a random screw and washer to plug up the hole, reinstalled the brake light switch, and amazingly, no lights or limp mode anymore. It wasn't a transmission or throttle body or mass air flow censor: it was a $0.15 part.
I am grateful to all of you for your help. I also wanted to post this, as the car loosing power and going into limp mode seemed to warrant a major mechanical issue that was transmission or engine related. I am by no means a car expert, but it's possible that in addition to all 3 lights, someone else may also experience "Limp Mode" if something is wrong with their brake system, especially if their car is an AWD like mine. Thanks for all your help and wisdom that came from all of you sharing your experience.
AustinErkl
Feb 8, 2021 06:41 AM
Instability_G35
Nov 26, 2014 07:58 AM
pernerat230
Jan 27, 2014 06:17 PM
Soundman
Apr 13, 2005 07:31 PM
Xattica
Mar 23, 2004 11:55 AM
