Bose system worth it?
Old Apr 17, 2003 | 01:17 PM
  #32
bigel's Avatar
Re: Bose system worth it?
After doing some more research, it looks like a custom install is the only way to change the system (if you want to, I won't be). The speakers are 1ohm, and using any other head unit will over tax that amp and blow it. Putting in aftermarket 4ohm speakers will cut your audio output by at least half if you use them with the factory amps. The only two things to do would be cut the dash, install whatever head unit and speakers you want. Or, figure a way to install two dual cone subs wired in parallel to cut over impedance to 1ohm.
This website has some interesting info about Bose systems:
www.carstereohelp.com
Oh, and I believe what they say about the adaptive EQ on the Bose. Make sense because like I say, mine sounded better after a few weeks of play. Overall I am happy with mine, and it came with the premium package. If you want to argue about manufacturers sticking it to you on option groups, then everyone in the industry is guilty of that.
Old Apr 17, 2003 | 05:17 PM
  #33
rajc007's Avatar
Since yesterday I've listened to different types of music and I think that they base system isn't so bad. I don't have a Bose system to compare it to, but when comparing it to the Harmon Kardon system in the bmw it holds it own. It would be nice to have the subwoofer that the bose system adds, but doesn't sound bad without it.
CB G35 Coupe 6MT
19x8/20x10 Axis Se7en Mods
Old Apr 17, 2003 | 06:19 PM
  #34
ReDRoK8's Avatar
BIGEL there is a third option as I mentioned above and I think it's the best. You go out and buy a good AMP capable of running all 8 speakers at 4 ohms. Then you buy all aftermarket speakers the same exact sizes that come in the car so replacement should not involve heavy mod's. Then either install them yourself or have a shop do the install making sure that you or they attempt to use the original wiring harness' for the speakers by connecting both the signal and the power cables to the factory harness behind the Head Unit. That way you still have all or most of the features and functions of the stock stereo. The signal will then pass from the factory signal outputs (hopefully Line Level RCA) or through a signal converter, (sold at most stereo shops) to the AMP. The AMPlifier will then power all the aftermarket speakers at 4ohms and with much more clean power. That is what I plan to do at least when I get the money. [img]/w3timages/icons/smile.gif[/img]
-Jason
Laser Red '03 6MT
Old Apr 18, 2003 | 11:12 PM
  #35
GeeBoy's Avatar
Who needs a stereo
when the engine sounds as good as this G does.
I got the Bose with the Prem Pkg, but spend all the time with the windows and gas pedal down. Radio off.
nissandrifter32
Dec 22, 2015 04:28 PM
JoeMac
Sep 28, 2015 12:28 AM
JustinMKN1
Sep 18, 2015 03:40 PM
G35-2004-mt6
Sep 11, 2015 04:16 PM
