Weird squealing sound.
Old Aug 27, 2010 | 05:15 AM
TigerKneeCrush's Avatar
So my car was parked at work and it was time to go home. I start it up and pull outta my parking spot. As I'm leaving I hear a loud squealing sound. What is that? Keep in mind I have an 04 and like high mileage.
Old Aug 27, 2010 | 05:19 AM
Also my AC/ventilation smells weird. Kinda like ****/window cleaner.
Old Aug 27, 2010 | 06:23 AM
LaserRedG35VS's Avatar
Check your belts, might be squealing. Mine did the same, i just applied wd40 and it went away, if it gets any worse later, you might have to replace. Idk what the smell could be from.
Old Aug 27, 2010 | 09:44 AM
gary c's Avatar
Belts require they be replaced every few years, they stretch/crack and will eventually break and leave you stranded. That's exactly what you're hearing/smelling, go to Nissan and buy the OE replacement belts they're way better than aftermarket....
Gary
Old Aug 27, 2010 | 11:55 AM
ericlee303's Avatar
I get that sqealing as well, and my belts are newer OEM. Could a pulley be seized?
Old Aug 27, 2010 | 03:05 PM
how much?
Old Aug 27, 2010 | 03:09 PM
Blue Dream's Avatar
I drove ttrank's car solo
Less than $40 for both belts, even at the dealer. Takes about 30 minutes to change them out yourself.
Old Aug 27, 2010 | 07:14 PM
gary c's Avatar
Originally Posted by ericlee303
I get that squealing as well, and my belts are newer OEM. Could a pulley be seized?
If you have fairly new belts and there making our favorite squealing noise, chances are good they weren't installed tight enough....slipping.
Gary
Old Aug 27, 2010 | 07:27 PM
Ok ill stop by talk to infiniti sometime
Old Aug 28, 2010 | 12:28 AM
tnmt_donkey's Avatar
Soryy I am new.
The belts you guys were talking about are the ones connect crank, a/c and alternator?
I want to put the light weight pulleys on too, a lot of work?? need to take front off??
Old Aug 28, 2010 | 01:37 AM
jef_gutjr's Avatar
Gary C is absolutely right. Check your belts, they are made out of rubber, they get brittle and start to crack. Also check the pulleys to see if they are loose, this can also cause a squel. Good luck!!!
Old Aug 28, 2010 | 01:53 AM
herrschaft's Avatar
Yes, they are talking about the (2) stock belts.
I had a shop install my pulleys because its a PITA. The fan assembly should be the only thing you have to remove.
Old Aug 28, 2010 | 08:59 AM
gary c's Avatar
Soryy I am new.
........ Yes you are, nothing wrong with being new and yes those are the 2 pulleys that need to be replaced. Before you make any changes/mods to your G investigate/research whatever it is before making any changes....example: lightweight/aftermarket pulleys are a bad idea and will mess your engine up!
Gary
Old Aug 28, 2010 | 09:54 AM
AMS pulleys've been receiving good reviews.
They are fully balanced, stock size....
just light weight...
Old Aug 29, 2010 | 12:46 PM
Sammy23's Avatar
my car also makes a wierd squeeking noise when i fisrt turn it on and amletting it warm up...and 30 seconds after i turn it off ill hear it again..sonds like a vacuum is loose or kinda like what a tire would sound like when its loosing a lot of air but at a higher pitch
