What Is This ? Rubber Band With Arrow In It, my air con not working since bose stereo
Old Sep 18, 2010 | 09:11 AM
R6n350GT's Avatar
Ok, what is this?
I pulled dash apart to swap my bose cd changer over after it failed as most do. somewhere along the line my air con got disrupted and now only blows hot air unless i switch it to manual mode or auto mode once at 18degrees (coldest setting) anything above this is warm....
Only other things changed are z-tube / pop charger and plenum spacer but they were not on before this started happening.
The only thing not plugged back in is this rubber band thing that i remember coming off under the glove box area off the dash... Any suggestions???
Old Sep 18, 2010 | 09:38 AM
spoolinupblue's Avatar
Did you check the plug for the sensor on the right of the cover under the steering wheel?
Air Condition Issue after Double Din Install
as far as the rubber band...i have no clue.
Old Sep 18, 2010 | 11:42 AM
joedaddy1's Avatar
isn't that from the throttle body?
it's the seal you replace when you clean/replace your throttle body right?
Old Sep 18, 2010 | 05:37 PM
R6n350GT's Avatar
Ok i watched a cleaning throttle body video and didnt see them take off a seal that looks like that.
I did notice under the steering wheel where that little panel is there is a thin plug not plugged into anything. Ill go check it out. But that thread explains my situation perfectly ! LEGEND guys !!! Thanks, ill let you know how i go
Old Sep 18, 2010 | 05:50 PM
Blue Dream's Avatar
I drove ttrank's car solo
That is definitely not from the throttle body. It has a metal gasket the goes between the TB and the neck of the plenum and it looks nothing like the rubber band thing.
Old Sep 18, 2010 | 06:01 PM
R6n350GT's Avatar
Ok Air con is FIXED
Step 1: http://img138.imageshack.us/img138/390/stickitkh5.jpg
Step 2: http://img175.imageshack.us/img175/8...nfilteroj5.jpg
Step 3: http://img166.imageshack.us/img166/2533/harnessig4.jpg
That fixed it, these are not my pics by the way but docron1 - cheers !
Now only to find out what the rubber band thing is for... Any clues?
Old Sep 18, 2010 | 07:45 PM
the_sedan's Avatar
dont worry bout the rubber band. you just left the incabin temp sensor unplugged.
Old Sep 20, 2010 | 12:57 AM
R6n350GT's Avatar
I hate not know what it was for lol! I dont like spare stuff after u put things back together again!
EnCr1pt3d
Jul 8, 2019 02:48 PM
hdmark
Apr 29, 2019 04:31 PM
Frostbite91
Aug 2, 2015 04:59 PM
kd03g99
Jul 30, 2015 11:24 AM
ZacDesu
Jul 14, 2015 11:13 PM
