Rear Axle click AGAIN >?!
My car is making the axle click sound again but from both sides, i got it fixed around 45k. But i dont think its the problem this time, it does this when going in reverse and forward. Any thoughts on this . Thanks
but im at 60k ! it didnt get it till 30k
did you get it fixed at the dealer or did you do it yourself and if so what grease did you use??
i fixed mine and it has been just fine for a couple thousand miles.... running smooth
Pull the axles apart and repack them with grease.
dealer for $60
^I would say yes but I only had this fixed once.
http://my350z.com/forum/engine-drive...rear-axle.html
mine didnt start clicking till about 45k miles and i fixed it myself my dealership wanted like 350 for parts and labor
. Anyways i went and bought the next best grease available becuase what the TSB ask for is the molykote grease from the dealership that is over $100. so i did it for a mere $25 and it only took an hour at most. ( which by the way it looked like there never was any grease to begin with it was so dry) So if you can use a wrench you can do this fix yourself. besides i made sure it was very clean with a wire brush and applied an extra amount of grease to make sure now it even goes into gear smoother.
try the dealer if you can though good luck
. Anyways i went and bought the next best grease available becuase what the TSB ask for is the molykote grease from the dealership that is over $100. so i did it for a mere $25 and it only took an hour at most. ( which by the way it looked like there never was any grease to begin with it was so dry) So if you can use a wrench you can do this fix yourself. besides i made sure it was very clean with a wire brush and applied an extra amount of grease to make sure now it even goes into gear smoother.try the dealer if you can though good luck
