Front Strut Brace
Old Oct 11, 2010 | 04:49 PM
G35Stan's Avatar
Front Strut Brace
Has anyone added this and if so did you notice any improvement cornering?
Old Oct 11, 2010 | 05:39 PM
Silencer_0's Avatar
Yes. Sways are better though.
Old Oct 11, 2010 | 08:49 PM
walshtj's Avatar
+1, and go with gt spec not NRG
Old Oct 12, 2010 | 09:01 AM
SECG35's Avatar
What braces fit with the Skunk2 (5/8") Spacer and do they also fit with the plenum cover? I really do not want to remover the cover which means I will have to Polish the plenum! OR what spacer and brace is recommended here.
THX
SECG35
Old Oct 12, 2010 | 10:28 AM
gary c's Avatar
The upper strut bar is a great mod especially when combined with aftermarket sways. You can turn on a dime with almost zero body lean, being lowered helps too....
Gary
Old Oct 12, 2010 | 12:18 PM
Silencer_0's Avatar
THX
SECG35
Typical setup is MotorDyne 5/16" spacer with a gt spec strut bar. You'll still be able to use your engine cover.
Old Oct 12, 2010 | 01:17 PM
walshtj's Avatar
+1 and I would rec Motordyne over Skunk...
Old Oct 12, 2010 | 01:51 PM
jayk's Avatar
Skunk Stinks.
Old Oct 12, 2010 | 02:59 PM
walshtj's Avatar
+1 on that.
Old Oct 12, 2010 | 04:45 PM
3rick35c's Avatar
Under Construction
as a matter of fact is it me or the damn NRG bar dont fit? i mounted it and the damn hood would not close due to the bar being too high? and yes I have lowered the bar to the lowest setting but no go...WTF???
Old Oct 12, 2010 | 06:43 PM
SECG35's Avatar
So; Motor Dyne it is, but which one( Basic, ISO Thermal or Copper)?
And 3rick35c you bring up an other point about NRG; are their hood dampers any good?
Old Oct 12, 2010 | 06:45 PM
walshtj's Avatar
Well if your living in Indiana I would go with atleast the iso-thermal, the copper iso-thermal is suggested if it snows in your area.
Old Oct 12, 2010 | 06:50 PM
WhosRich's Avatar
GT Spec strut bar helps but its very minor. If you're going to get sways, remember to get new endlinks as well since your oem ones are liable to become worn prematurely.
Old Oct 12, 2010 | 06:51 PM
gary c's Avatar
Get the MotorDyne 5/16" ISO Copper Spacer and you can keep that OE engine cover and even use most upper strut bars that are adjustable and installed correctly.... No, if you get aftermarket sways also buy the adjustable endlinks, that keeps the bitch tight & flat!
Gary
Old Oct 12, 2010 | 06:58 PM
SECG35's Avatar
I do live in Indiana but the car will NOT be driven in the winter, so which one is the best.
