Winter tires
Old Oct 21, 2010 | 08:59 AM
rico86's Avatar
Winter tires
Hi guys,
I have a 2005 g35 2sr coupe. Now i'm pretty sure I just have the base model.
Now I still lived at home last winter so i was able to put it away for the winter. I now have my own house and don't have the luxury of putting it away and driving my parents cars. I need tires badly as we do get quite a bit of snow where I live.
Most placed that i've seen are asking like $400 per tire for snows.
So i found a set that was only used for 1 winter, look in good shape and the guy wants $500 total, 4 tires no rims, 1 winter season on them.
Sizes;
225/45/R19
245/40R19
Will these fit my car first of all and secondly since I didn't drive it last year, will winters even make a difference or is this car really not meant to be driven in the snow. Thanks for youe help!
Old Oct 21, 2010 | 09:52 AM
Swivel's Avatar
Moderator
Yes they will fit if you have the 19" sport wheels (pictured below) since they are the OEM size for this rim and yes they will help a lot for winter driving.
Old Oct 21, 2010 | 10:58 AM
rico86's Avatar
Here is my car, i'm pretty sure they are the same tires you mentioned?
Old Oct 21, 2010 | 11:26 AM
Swivel's Avatar
Moderator
Yup, you're good to go. Just take them to a reputable shop, don't let some ham-handed shop monkey scuff them all up for ya! Better yet, if you can swing it, get a spare set of less-worthy wheels to bash through the winter.
Old Oct 21, 2010 | 11:29 AM
msommers's Avatar
If at all possible, I would suggest to come down a size. Look around and see if you can find 17" or 18" rim/tire combos in a 5x114.3 bolt pattern. Used is perfectly fine.
While having winter tires is better than all seasons (or summers clearly), coming down from a 19" will be beneficial and saves your forged rims from gravel and salt on the roads.
Don't forget a staggered setup for the vdc to be happy
Old Oct 21, 2010 | 11:42 AM
rico86's Avatar
Thanks guys.
Oh im definitely getting another set of rims for sure.
I've priced out 4 rims + tires and im looking at like 1500$ as the cheapeast deal.
Most places here want like $400 per tire for snows so i figured a set that was used for 1 winter for 500 is a good deal even if i do have to go buy some other rims.
Old Oct 21, 2010 | 10:43 PM
dave's Avatar
Have you tried tirerack.com? I bought a set of winter wheels/tires from them several years ago, and I don't remember them being that expensive. Try giving them a call.
Old Oct 22, 2010 | 05:52 PM
moonsin's Avatar
ever consider going down to 17s??? 19s seem lil too much for winter especially with those random potholes that comes up....tires might come out maybe cheaper too....got my rims+tires for like 1100 last season
Old Oct 22, 2010 | 06:35 PM
EF21's Avatar
Buy a beater as save your car. I have a oem 19 n was considering oem 17 with winter tires, but the price tires and wheels was to much so i bought a beater. I only drive my G on sunny days.
Now i can save for more parts.
Old Oct 23, 2010 | 12:57 PM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
get 17's or 18's at the biggest, don't spend to much on the rim. Bridgestone Blizzacks are amazing and there reasonably priced. I have Bridgestone blizzack 235/50/R17 in the back and 225/50/R17 in the front, when i change these tires out i'm going to go to a bigger sidewall (60) and probably 235's on both to give me more height (clearance). This will make the tires just over 1 inch bigger diameter wise, which is 1/2" radius increase so my ride height will be 1/2" higher.
I would suggest doing the same, obviously the car will handle a little differently but its better then bottoming out everywhere, 4 inches snow and were screwed, but hopefully with the bigger tires i can do 4 inches of snow and be fine, thats the cut off for people going out in winter for the most part anyways, so if I say i will be late because of snow they don't question it.
EasySausage
Sep 24, 2015 01:06 PM
JG_G35
19 Inch
14
Sep 19, 2015 09:04 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
