Has anyone with 18K+ miles NOT had a problem?
Old Oct 20, 2004 | 05:22 AM
shivak's Avatar
Paint chipping, premature clutch wear, awful trannies, warped rotors, brake pads that squeal and only last for 5000 miles, broken window motors, and the list goes on...
Has anyone driven their G35 for 18K miles and only had to do normal oil maintenance?
Old Oct 20, 2004 | 07:00 AM
Raznips's Avatar
Re: Has anyone with 18K+ miles NOT had a problem?
5000 miles and my window motor has gone out and now i am having problems with speakers and bose stuff that a lot of others are complaining about (left side sound going out).
I was looking at bmw 330s before this car and i am still glad i chose the g35 cause i worked all summer full time and everyday on my commute i saw at least one if not more bmw's on the side of the road broken down....i would rather have a car with electronic problems that are minor and easy fixes than a car with mechanical problems that prevent it from running..... i live near a dealer and dont mind getting a free wash every couple of weeks with a repair. My mom has a g35 sedan and has had zero problems and she's at a little over 10k miles
2004 Black on Black g coupe 6spd.... aluminum pedals, clear corners, z tube, and pop charger. soon to have 19" volk gt-c's and PIAA xtreme whites in the clearance and corners
Houston Texas
Old Oct 20, 2004 | 07:48 AM
timm's Avatar
'04 5AT w/ 20K + 1 driving school & 1 track day = No problems whatsoever. Changed to metal matrix pads for track day at 15K, kept stock pads w/approx. 30% wear for winter. Drives great, no complaints here.
Old Oct 20, 2004 | 07:53 AM
kevink's Avatar
Just under 11K, and other than a little glazing on one, most of my brake pads remain.
The only other issue is, if the passenger seat is all the way back, I get an occasional rattle.
2004 Sedan/DVD Navigation/Desert Platinum/Willow
Old Oct 20, 2004 | 08:38 AM
XCELR8's Avatar
Nope. New drivers seat cushion, window streak TSB, axel re-torque, and new trans/clutch. All took a dump at 22K.
2003 BLK/BLK 6MT Injen, clear corners, Eibach sways and springs, tint
My G on a photo shoot. More to come!
Old Oct 20, 2004 | 10:19 AM
radjack79's Avatar
A couple paint chips, but other than that...all is fine with her.
04 Laser Red 6MT
25% Tint
Partially Debadged
Old Oct 20, 2004 | 10:29 AM
myTBG35's Avatar
I have about 21k miles on my 04 Coupe. No problems except for the ones I caused. Gone through a set of front pads so far covered by warranty.
Old Oct 20, 2004 | 12:58 PM
G35pm's Avatar
+25k No problems so far. Paint could be better. A bunch of rock chips on the bumper and scratches a bit easy.
Love the car.
Old Oct 20, 2004 | 01:17 PM
SixFive's Avatar
minor stuff that's expected with a new model. Seat rocking; rattles from the window and then a grease streak, stock pulley failure, brakes at 22k. All covered. Also the brake light TSB. and I had the seat control tsb done for fun.
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Oct 20, 2004 | 03:00 PM
EX250's Avatar
No problems at all other than a sheered off plenum bolt @ 14 K (right as I put on the crawford plenum). I've had "grease streaks" but I have this thing called a shop towel so I dont get that picky. Other than that, no problems whatsoever.
2003 Black 6MT
JWT/Z tube, UR pulley set, Crawford Headers, Cats and v5 Plenum, Injen SES, TS ECU Crawford tuned, JDM Pedals, JDM battery cover, G-tech RR.
More mods to come....stay tuned.
Old Oct 20, 2004 | 03:43 PM
TopTech's Avatar
Early '03 AT Coupe. Only window creaks, grease marks, rattles, etc. I feel SO lucky when I read all the other crap folks go thru.
Old Oct 20, 2004 | 04:02 PM
Z2G's Avatar
Z2G
2003 coupe purchased dec '02 -- 23k miles - only grease streak and brake light tsb done at 15k miles maintenance. no paint chips due to clearbra installed within the first couple months of purchase. overall, EXTREMELY happy with purchase and have had NO other problems: )
Old Oct 20, 2004 | 05:49 PM
kwakman's Avatar
23k+ with no problems at all so far. Crossing fingers! I have minor issues but I don't even consider them problems. Like the grease streaked windows and squealing brakes...you get used to it. heh. Btw, when is a good time to change out brake pads? Still on the stock set and I don't feel any difference from the day I got my car til now. Weird...
'03 G35c DG/G 6mt, full options
clear corners, tint, z-tube/popcharger,
nismo titanium shift ****
Old Oct 20, 2004 | 06:45 PM
kevink's Avatar
Actually, about 5 weeks ago I did a full hand cleaning (first I've personally done on the car), and I did find chipped paint on one spot around a rear wheel well.
I bought a bra for when I drive on the highway.
