Trunk Will Not Open Sometimes...
Old Nov 9, 2010 | 02:41 PM
G35_FL_Girl's Avatar
50% of the time, my trunk will not open with the switch in the car or the remote. I have to turn the car on and then hit the trunk switch in the car for it to open. They have already replaced the computer in the trunk and the trunk actuator. I have taken it in 4 times and they can't figure it out. The trunk does not make any noise when I am trying to open it.
Have you heard of this problem?
Old Nov 9, 2010 | 04:18 PM
Silencer_0's Avatar
There's actually quite a lot of threads regarding this problem, just do a search for "trunk won't open" and set the Sort by: to Relevancy.
A suggestion from one of the threads:
Originally Posted by TechFarmer
Follow-up: I figured out the problem. At least on my car. Be sure the car is fully stopped before shutting off the ignition. If the car is rolling and the key is switched off, the trunk release remains disabled (it is automatically disabled when the vehicle speed is above zero).
Old Nov 10, 2010 | 08:46 AM
viceversa's Avatar
hmmm this has happened to me only a couple times. one problem I have more often is the trunk button in the tail light sometimes works...sometimes it doesn't...despite turning the car on and off. lol still havent figured this one out.
Old Nov 10, 2010 | 09:00 AM
Wow, thanks! I bet that is what it is... I usually always turn my car off before it stops moving, because my car is a manual transmission. I'm going to test this out! I'll let you know if it works.
Old Nov 10, 2010 | 09:04 AM
Kuneff's Avatar
Mine does that as well.... I will be giving TechFarmer's idea a try... I know there are times I roll into my garage and shut the car off as its still rolling... So that very well may be my problem...
Old Nov 10, 2010 | 03:59 PM
lcysimon's Avatar
This happened to me once..... I'll try to fully stop first and see if it'l lever happen again...
Thanks for tip!
Old Nov 10, 2010 | 04:18 PM
jibberjabbers's Avatar
Why would anyone turn off the car before it fully stops? To save gas?
Old Nov 10, 2010 | 04:33 PM
Kuneff's Avatar
when i am rolling into my garage sometimes I will shut it down as it rolls the last foot or two.
by the way JJ, I thought you died or something.... Where you been hiding???
Old Nov 10, 2010 | 11:17 PM
herrschaft's Avatar
^He's been busy creating another blog.
Old Nov 13, 2010 | 07:36 PM
ryno23's Avatar
happened to me too, i opened the trunk through the backseat and when the trunk is open, theres like a rubber tubing that houses all the power to the trunk im pretty sure and on mine the green ground got cut somehow and it must have shorted it out so i used a terminal and connected em and that solved the problem enitrely, if its not the ground wires on urs then it could possibly be some of the other wires running through that tubing.
Old Nov 13, 2010 | 07:43 PM
Project's Avatar
Hammer fixes anything people.
Claudiu
V36 Brakes, Suspension, Wheels & Tires
Mar 10, 2018 11:38 AM
g.spot
May 9, 2016 10:54 PM
Claudiu
Sep 26, 2015 01:04 PM
vamarris
Sep 26, 2015 12:56 PM
