Problems Getting Up Carport
Old Nov 28, 2010 | 04:06 PM
klevr's Avatar
Okay so here's the deal: My car is lowered on Eibach Pro Kits and I have the stock 17" rims. I'm moving into a new house and my car can't make it up the initial hump for the carport. The car makes it up fine until I get to the rear end and the exhaust (I'm assuming) starts to scrape real bad. I want to avoid having to replace the springs and shocks back to stock or something higher, but I may have to.
My question is this: First of all I haven't tried backing up into it yet because I'm afraid of damaging the car. Would it generally have less clearing issues backing into the carport? Also, I was planning on buying new rims in the near future anyways, so if I got rid of my stock 17s and got 20s would that add a lot of height to the vehicle or does that not change much?
Old Nov 28, 2010 | 04:09 PM
w4kj4k's Avatar
If you get bigger size wheels then yes your car would be higher off the ground
Old Nov 28, 2010 | 04:11 PM
Tjeh's Avatar
Put some wood or something by the curb, might help. I had to do that before.
Old Nov 28, 2010 | 04:14 PM
klevr's Avatar
How much higher off the ground would new wheels make the car?
Also, I think the wood thing is a great idea but I'd like to avoid having to drag a piece of wood in and out of the garage everytime I want to get into my house.
Old Nov 28, 2010 | 04:52 PM
dave's Avatar
I don't think bigger wheels will increase your ground clearance. When you get bigger rims, you get tires with smaller sidewalls.
Old Nov 28, 2010 | 05:36 PM
klevr's Avatar
Hmm good point. Should I just get coilovers and raise my rear end? It currently scrapes so bad that I refuse to take it up the driveway, it's not like it's just a little scrape.
Old Nov 28, 2010 | 05:44 PM
Deepdiver's Avatar
I would pour concrete in the driveway approach. Pour the concrete over a schedule 80 pvc pipe to maintain drainage if necessary.
Old Nov 28, 2010 | 06:38 PM
the_sedan's Avatar
are you going in at an angle?
Old Nov 28, 2010 | 06:56 PM
klevr's Avatar
Yeah I am, do I need to be at a sharper angle on the back maybe?
Old Nov 28, 2010 | 07:47 PM
the_sedan's Avatar
go in as sharp as you can. if anything you should be scrapin your ypipe, but if you're scrapin your muffler you must have a serious incline to go up.....pix of your car going up it?
Old Nov 28, 2010 | 08:40 PM
TemjinX2's Avatar
i say just buy some long pieces of wood from home depot for $10. It's the cheapest way of solving your problem short of going back to stock height.
Old Nov 28, 2010 | 08:43 PM
spoolinupblue's Avatar
+1 for the pics....must be one heck of an incline!
bananax
Sep 24, 2019 12:24 PM
G35xdriver04
Nov 7, 2015 08:31 PM
itgogitrev
Sep 23, 2015 07:08 PM
mattdg35
Sep 14, 2015 11:28 AM
