Starting issue heeeeeelp
Old Nov 30, 2010 | 09:03 AM
Gee35init's Avatar
So I parked my G for the winter, I went to start it to move it back and forth yesterday, I pushed in the clutch and turned the key. The sound that came out of the engine was like that of the sound you would here trying to start a car that's already running? Yet this was the initial start. I've just had a ACT clutch, and stillen fly wheel installed, the car never made this noise previous to the install of the clutch/flywheel?
Any ideas on this topic?
I'm thinking the install was done incorrectly!?
Old Nov 30, 2010 | 10:58 AM
apro06g35's Avatar
are you sure it wasn't clicking because the battery is dead?
Old Nov 30, 2010 | 11:10 AM
danielj's Avatar
From: Winnipeg, MB (Biggest/Coldest city in the world)
battery.
Old Nov 30, 2010 | 02:11 PM
spinna001's Avatar
Might be the starter. It will happen if its cold and you have not start car in a while.
Old Nov 30, 2010 | 03:42 PM
lcysimon's Avatar
If it's not the battery, you might need a new starter.
Old Nov 30, 2010 | 09:18 PM
the_sedan's Avatar
i havent had to replace a starter in a G/FX in my 2+ years at this dealership so im betting on the battery. get it tested. or maybe ur just a lucky pick and need a starter lol. and make sure ur battery terminals arent corroded and nice and tight.
Old Nov 30, 2010 | 09:27 PM
LMG_35C's Avatar
Starter gear may not be fully engaging the flywheel or it might be loose and could be damaging the starter pinion gear. it's possible that the starter wasn't properly installed when the clutch and flywheel were replaced.
Old Nov 30, 2010 | 09:29 PM
the_sedan's Avatar
this is true...i overlooked the part of having a new clutch kit put in. def check and make sure the starter is installed correctly. if its not, hope it didnt do much damage to the ring gear :/
Old Dec 1, 2010 | 01:32 AM
626Gthirtyfive's Avatar
Same problem happened to me today. Tried starting the car today but it wouldn't crank. After many tries (over 10) the car finally started. When it finally started, I heard a loud popping noise coming from the rear of my car, sounding like metal popping. I'm pretty sure it's not the battery, because it finally started after attempted tries..
Old Dec 1, 2010 | 07:07 AM
Gee35init's Avatar
It's not the battery, it's a terrible grinding noise it turns over every
time it just doesn't catch, it's gotta
be when they did the work on my clutch for sure it never did this until that work was done. Thanks or your help guys appreciate it, what kind of damage would this do it's happened about 10 times
Old Dec 1, 2010 | 09:02 AM
Darkblizz's Avatar
odd... i dunno how they mess up on a clutch O.o.. Just had mine fixed but, gl man!
Old Dec 1, 2010 | 07:14 PM
LMG_35C's Avatar
Depends on lot's of things. Chances are it may not have been too badly damaged. Even so, the pinion gear could probably be replaced without having to shell out bucks for an entire starter. You can pretty easily remove the starter and see for yourself, and while your at it determine why it may not be fully seated.
...time to get to work. it's not gonna fox itself
chinee
Jun 10, 2024 07:48 PM
Terry_G35
May 9, 2020 01:39 AM
MyfistYourFace
Aug 8, 2015 11:58 AM
D1dphresh
Aug 7, 2015 06:10 PM
itschuckster
Jul 25, 2015 08:07 AM
