Finish installing stillen/z-tube. Does it look right? (PICS)
Old Dec 3, 2010 | 06:45 PM
cHink's Avatar
Originally Posted by gary c
***** you do need help! When installing the z-tube/intake all you need to do is remove the negative side of the battery and put it back upon completion. *****, do not mess with the ECU....ever!
Gary
Uhm i just took off the ECU(not unscrewing the screws) i was trying to hard to take it off but i finally took off the plug. I didnt unplug the Negative battery, will anything go wrong?
So here is the picture that i just finish installing a few minutes ago and i think it looks right. Tell me if anything is wrong with it. I had a hard time of figuring out which way is the Z-tube cause the stock G-Tube hose is pointing up and tryna figure out which way does the Z-tube hose faces.
im not sure if this is the ac line you guys want to protect but this is a picture i took this morning and it is very close to my tube. I have read the JWT Pop Charger thread about protecting the AC Line but i tried to move it and it doesnt even move.
Old Dec 3, 2010 | 08:31 PM
G35er06's Avatar
Install looks good to me... Ztube hose will face down and that's fine. I would have just unplugged the battery for a reset though. Anyways you should be ok as per the pics.
Old Dec 3, 2010 | 08:39 PM
JJSOLON's Avatar
Looks good! Just make sure that your tube is not rubbing on you ac line.
Old Dec 3, 2010 | 08:55 PM
Swivel's Avatar
Moderator
Looks okay to me (I have one too)
Old Dec 3, 2010 | 09:06 PM
the_sedan's Avatar
dont mess with the ecu plz.....and you're supposed to disconnect the battery to be on the safe side.
Old Dec 3, 2010 | 10:09 PM
spacecitygroove's Avatar
what site did u uploade the pics on?
Old Dec 3, 2010 | 10:49 PM
GEDsetG35's Avatar
my bro is getting me a intake for xmas and reading some comments Do i have to disconnect the battery??
Old Dec 3, 2010 | 10:52 PM
GarGamel's Avatar
looks good to me.
Old Dec 4, 2010 | 12:23 AM
SofaKingG's Avatar
Why does the battery need to be disconected??? Im confused!?!?!?!?
Old Dec 4, 2010 | 12:30 AM
cHink's Avatar
^ idk.. i just took off the ECU without disconnecting my negative battery.
i dont understand. The ztube and the G-tube is just the same except Z-tube dont got the air chamber. Its like the same set up. But u got any pics of how the ac line and ztube suppose to look like so that its not rubbing?
Old Dec 4, 2010 | 12:35 AM
thescreensavers's Avatar
Mr.202?
^ Check this thread
https://g35driver.com/forums/intake-...e-ac-line.html
Old Dec 4, 2010 | 12:36 AM
G35er06's Avatar
It's a way to reset the ECU after the install
Old Dec 4, 2010 | 01:32 AM
lcysimon's Avatar
Lookin good, but you can always do the pedal ecu reset so you don't have to reset everything.
Old Dec 4, 2010 | 11:09 AM
gary c's Avatar
You have two holes in the top of the Stillen cover, you can buy a couple push pens (Nissan) to cover those holes. Can't wait for ****** next post....
Gary
Old Dec 4, 2010 | 12:54 PM
cHink's Avatar
^ thanks gary, i will look for that when i have time
