Going to look at a G35 today and have a few ??
Old Dec 10, 2010 | 05:22 PM
SilverMamba's Avatar
Originally Posted by 2003G350S
No dents or tears? You may have just got the best deal on a G ever... I picked up my G sedan for the same price with 105k miles but, that was from a good friend. Congrats!
there was one accident reported on the carfax to the front left fender but it looks great...
Old Dec 10, 2010 | 05:28 PM
what should i do about the clutch gang? I am assuming the dual flywheel should be fine or will it need to be spun with 96K on the odo?
also what brand of clutch and spark plugs??
Old Dec 10, 2010 | 06:00 PM
jibberjabbers's Avatar
Do you have oil on the plugs? If so you will need to replace your valve cover.
Brand of Clutch? I told you, you can't go wrong with Exedy. I would stick with OEM though.
Expect some clutch chatter on the Aftermarket clutch and flywheel. You MAY be able to resurface the OEM flywheel. But if you're going to replace the clutch, might as well replace everything. They usually come in combos anyways.
Spark plugs, brand don't matter. Most people stick with NGK.
Old Dec 10, 2010 | 06:07 PM
where do you guys get OEM parts? u picking stuff up at the local dealer? IDK how the plugs are. I will have the guy doing the clutch check that out. Car fired right up stone cold and seems to run great other than the clutch. Any symptoms of oil on plugs?
Old Dec 10, 2010 | 06:18 PM
ummmm the flywheel is 860 bucks for the OEM one...is this right?
Old Dec 10, 2010 | 06:23 PM
also, i see that one of the exedy kits has a solid flywheel that replaces the dual mass...is that a big deal??
Old Dec 10, 2010 | 06:28 PM
how about this kit? does this seem reasonable as it comes with a flywheel...if not send some links for me! lol
http://www.importpartspro.com/jwthdclco03i.html
Old Dec 10, 2010 | 09:38 PM
TemjinX2's Avatar
good luck
Old Dec 10, 2010 | 11:45 PM
been doing some reading and could this be a clutch adjustment issue??? the clutch on the car never slipped BUT only engaged the last two inches of the pedal....
thoughts???
Old Dec 11, 2010 | 11:34 AM
2003G350S's Avatar
Definitly start with that idea before sinking the money
EnCr1pt3d
Jul 8, 2019 02:48 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
