toe question!?!
Old Dec 10, 2010 | 03:29 PM
drew89's Avatar
toe question!?!
is it bad to put your toe in spec about .1 or even 0? whats the normal spec for toe? im asking because my wheels are pretty aggressive and im cambered so im trying the best way to save tire. thanks
Old Dec 10, 2010 | 03:47 PM
wanabskyline's Avatar
I have been running mine for a year at -2.5 camber and zero toe to save the tires. They are just needing to be replaced due to inside wear. I drive very aggressively and drift my car alot. I dont remember the spec off the top of my head, but all you will loose is a hardly noticeable amount of response for normal driving.
Old Dec 10, 2010 | 04:10 PM
drew89's Avatar
thanks for the comment, but i just called my mechanic and he said since im dropped 3 inches, if i put the toe at 0 it would give me even more inside camber wear.
Old Dec 10, 2010 | 04:18 PM
LightsOut's Avatar
SIETESG
closer to zero is better for tire wear.
Old Dec 10, 2010 | 08:57 PM
the_sedan's Avatar
we set the toe to around .18 total toe.....oem spec is .08. the more positive toe helps against the rapid wear and feathering of the front tires.
Old Dec 10, 2010 | 09:43 PM
TemjinX2's Avatar
toe eats tires more then camber. I would keep it at 0 or within oem spec like others have said.
Old Dec 11, 2010 | 10:23 PM
brandon1978's Avatar
Toe changes with speed. On a RWD car, the fronts will move out and the rears will move in. For the best wear on the fronts set it to max toe-in spec of .08°. At highway speeds that should be about zero toe. Both the G and the 350Z will eat up inside front tires if the toe isn't set right. The 350Z has a TSB describing this: NTB04-043a.
https://g35driver.com/forums/g35-cou...-set-zero.html
frankywashere
Aug 26, 2015 09:53 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
jimNC
Jul 25, 2015 05:47 AM
