Transmission Question Help please
Old Dec 25, 2010 | 03:59 PM
Sp33dY's Avatar
Question Transmission Question Help please
Hi everyone I know I will be getting a lot of people saying oh this car isn't made for this/that blah blah... So if you're going to comment on that please don't I just want some advice from people who actually drag/track their cars. And before I ask my question my car is stock except a filer and stillen ztube. Future plans are spacer, KCR exhaust, TP, MREV2, Tune. I'm thinking about wanting to push about 300WHP if possible from some mods without doing FI. So here is my question
1. What Clutch/flywheel would you recommend because with the stock the clutch is too sticky most 6MT ppl know what I'm talking about( when launching the clutch pedal gets stuck half way up and burns the clutch. But my car is my Daily Driver so I would like a clutch that is DD friendly.
2. With the mods I have posted what else would you recommend for me to do to push about 300 with a Osiris or Church Automotive tune one of those 2 they are the closest to where I live. Headers? Pulley? anything that would get me to 300 mark I have not had a stock pull done so I don't really know how much I'm pushing can you guys post stock pulls with the revup engines please.
Thank you all Merry Christmas and Happy Holidays
Old Dec 25, 2010 | 04:03 PM
Sp33dY's Avatar
Sorry if there are spelling or grammatic mistakes posted this with my phone lol I was thinking about doing this but I can't really find much reviews on JWT HD Clutch & Flywheel Combo. Help please.
Old Dec 25, 2010 | 05:04 PM
gary c's Avatar
Lets begin with the clutch, there's no better clutch/flywheel combination than ACT. The best HP increase can be found by using MotorDynes MREV2 and 5/16" spacer along with HFCs. Pulleys....NO! Headers.... if you need that extra 3 to 5 HP to reach your goal and have the extra $$ go for it. Osiris along with a knowledgeable tune shop would work for the final tune after all the above are installed.
Gary
Old Dec 26, 2010 | 01:04 AM
TemjinX2's Avatar
i dont think your going to be able to hit 300whp with bolt ons. Your going to need cams and high compression pistons to hit 300whp without FI.
Old Dec 26, 2010 | 01:32 AM
gary c's Avatar
As I recall the '07 Revup motor is within 25 HP of hitting 300 from the factory so the above mods I posted will get him damn close if not over....
Gary
Old Dec 26, 2010 | 02:05 AM
TemjinX2's Avatar
Gary
stock g35 dynos around 240-250whp
With intake he only gained 7whp. I really doubt he'll get 50whp from the mods he listed without FI.
Old Dec 26, 2010 | 02:59 AM
P-JDM's Avatar
I've got an ACT HDSS that is running strong with about 70k miles on it and its my DD most of the time.
Old Dec 26, 2010 | 03:42 AM
OBsessed's Avatar
When you replace the clutch add stainless steel lines and don't replace the fluid with DOT3, go with DOT4. Heat is one of the biggest causes of the sticky clutch pedal so go with lines that won't stretch and fluid that won't boil as quickly.
Get a baseline dyno done, see where you're at. That'll help you figure out how much work you're going to have to put in. We can only guess from previous threads where you'll end up but I'm with Tem, I don't think you'll hit 300 with a few bolt-ons unfortunately.
Also consider changing the final drive. Are you looking for drag strip performance or autocross/HPDE track days? What kind of racing are you setting up for?
Edit: And don't overlook your wheels either, a lightweight set of track wheels to reduce unsprung weight may help you out some too. If you've got the factory 19s you're OK here, if not look into getting a set or some lightweight Enkei or Weds or something.
Old Jan 4, 2011 | 05:27 AM
andrewstclair's Avatar
+1 for the dot 4 and stainless lines. for the clutch i found i wore out the 6 pucks kinda quickly and if your only going for 300 they arent needed. get the strongest pressure plate with a good street friction plate it will last longer that way.
saskicker32
Aug 11, 2015 02:12 PM
Srinidhi
Aug 7, 2015 03:38 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
socalg35x
Jul 28, 2015 10:42 AM
newg37
Jul 26, 2015 09:32 AM
