ztube question
Old Jan 3, 2011 | 07:28 PM
socialconflicts's Avatar
ztube question
the sedan section didnt bring clear answers so im asking here now lol
i have heard mixed reviews and yet to conclude it before i proceed to anything.
i heard battery needs to be disconnected to install ztube to avoid CEL.
but at the same time i heard it doesnt need to be unplugged because it is generally the same thing. (this seems correct to me)
so any input is greatly appreciated.
Old Jan 3, 2011 | 08:02 PM
develop1's Avatar
While installing the z tube the battery does not need to be unplugged.
But, you might want to unplug it to do an ECU reset. There are two ways to do this: the brake pumping trick or unplugging the negative from the battery. But if you don't plan on resetting your ECU no need to disconnect the battery.
Old Jan 3, 2011 | 09:06 PM
WataG's Avatar
The battery does not have to be disconnected but when working on the car it is recommended. Besides, it only takes 2 seconds.
Old Jan 3, 2011 | 09:22 PM
atmel101's Avatar
Originally Posted by watag
the battery does not have to be disconnected but when working on the car it is recommended. Besides, it only takes 2 seconds.
+1.
Old Jan 3, 2011 | 09:57 PM
sillyoldtayo's Avatar
x3 on not disconnecting it. Also it didnt throw a CEL for me. its not really a power adder so I didnt think it would do much resetting the ecu
Old Jan 3, 2011 | 10:25 PM
dukehotty's Avatar
I would not disco the battery but I would recommend doing an ECU reset using the gas pedal. I know the tubes are supposed to be the same but it made a difference for me.
Old Jan 3, 2011 | 10:28 PM
gary c's Avatar
Coupe pilots are measurably smarter than those four door sedan dudes. (there are a few exceptions like Marcus) When installing the Z-Tube you don't need to disconnect the negative side of your battery. It's also not a good idea to leave it disconnected for any length of time since your ECU will forget why it was installed in your G. Any thing more than a few hours and you'll be doing a SEARCH for the low idle reset....G/L
Gary
Old Jan 3, 2011 | 10:41 PM
dukehotty's Avatar
Gary
That would explain why my G acted like an ahole after being disco'd for 24 hours. +100000000000000000000000000000000
Old Jan 3, 2011 | 11:32 PM
cool, thanks guys!
so i made my decision, i will not unplug the battery, i do not plan to do an ecu reset, unless i notice anything different. but all in all, it should be the same
Old Jan 3, 2011 | 11:38 PM
SDGenius's Avatar
dang dude, you coulda just PM'd me or asked on the SD boards. you didn't have to start a whole new thread for this.
Old Jan 4, 2011 | 12:02 AM
^ lol i asked a few people. and i got different answers. which is why i decided this needed clarification. i did search before!
Old Jan 4, 2011 | 03:32 AM
andrewstclair's Avatar
you should throw codes unless you do something retarded like turn the car on while things are unplugged which i have done lol.
Old Jan 4, 2011 | 03:35 AM
thescreensavers's Avatar
Mr.202?
He did ask in the Random question thread and I answered him but he never answered back. Who says the ztube can cause the CEL? I want to lol at them
Old Jan 4, 2011 | 02:22 PM
saywat?'s Avatar
^ ud be surprised how many tards get cel after installing jus an intake lol
Old Jan 4, 2011 | 02:55 PM
Sp33dY's Avatar
With just a z-tube you will not see a huge change with or without the ecu reset most people would recommend it but you dont have to do it. I dont know how you can get a cel from this how stupid can you be to do something so wrong it throws the cel. But like most of these people said no need for anything I did it to mine I changed the ztube and afe filter just thought it would be a good idea to do it. It only takes 10-20 mins max to install the ztube. Good luck with the install
