Window Problems
Old Jan 15, 2011 | 06:23 PM
nevets11_2003's Avatar
Window Problems
So I have had my G35 Coupe for around a year and a half and the only problems I have had thus far are all contained within the doors. At first the passenger side door lock died, and eventually the drivers side. Now when I pull two clicks up on the drivers side window switch (auto up) and let go it will roll all the way up, then roll half way down once it seals. However if I only pull up one click, and roll the window up (manually basically) it stays shut.
Is this is problem with my switch or my window motors?
Any thing I can do to fix (without taking the door panel off) such as computer cleaner on the switch?
Old Jan 15, 2011 | 06:27 PM
walshtj's Avatar
Mine was doing that and it happened to be the notorious window motors so id go get it checked out.
Old Jan 15, 2011 | 07:36 PM
crashnburn's Avatar
yea mine has done this for 2 years now.. i even close my tl windows the same way cuz im so used to it now... just need to get new motor.. auto parts store has them for 140 with a lifetime warranty.. wy better than dealer 180 that works for maybe a year or 2.. im on my 3 rd set on my 03 driver and passenger...
Old Jan 15, 2011 | 07:38 PM
It seems like it only acts up during cold weather. I think it did this last winter as well but it eventually stopped around spring time. My major concern is it getting stuck down.
Old Jan 15, 2011 | 09:38 PM
walshtj's Avatar
Def but you could always manually roll it up if that happens...But that involves taking off the door panel. I think in the marketplace you can get a motor for pretty cheap.
Old Jan 15, 2011 | 10:04 PM
Energizer's Avatar
If its going halfway back down on you it, only rolling up all the way when you do it manually,.... means you need to reset the window motor. Its located inside the door panel behind a black sticker. Had the same thing happen to me.
Old Jan 24, 2011 | 01:03 AM
Could you further explain where it is? a picture perhaps?
Old Jan 24, 2011 | 12:29 PM
BW350GTskyline's Avatar
yea the window motor seems to be this infamous issue.. if your not covered with warranty that is going to run you about $230 just for that alone...
Old Jan 24, 2011 | 08:25 PM
Energizer's Avatar
Its one of the smaller stickers in the middle, on the right side.
heres a link.. https://g35driver.com/forums/body-in...l-removal.html
Old Jan 24, 2011 | 10:35 PM
JetsoN's Avatar
Here is another thread that contains a video: https://g35driver.com/forums/interio...w-problem.html
mike730
Jan 12, 2018 04:25 PM
leo38cheng
Nov 12, 2015 06:49 PM
cmesidewayz
Sep 29, 2015 09:28 PM
gatorglaze
Sep 10, 2015 12:03 PM
Jnm07
Sep 5, 2015 01:16 AM
