Sedan vs coupe 6MT clusters
Old Feb 4, 2011 | 01:00 PM
2one8's Avatar
I found a gauge cluster from a sedan that was a manual w/o nav. I need one for my coupe 6MT. Is there a difference between the two?
Old Feb 4, 2011 | 02:33 PM
wbama387's Avatar
Im not 100% sure but i believe there is. I was looking at swapping mine out and when i was doing research i think i remeber the mounting tabs being different.
Old Feb 4, 2011 | 02:48 PM
ray1370's Avatar
What year was the sedan? If it's 03/04 it should swap directly with yours, but if it's 05+ then it needs to be modded.
Old Feb 4, 2011 | 02:54 PM
2one8's Avatar
its teh same style as mine, looks identical, just not sure if the electronics part is any different.
Old Feb 4, 2011 | 03:00 PM
ray1370's Avatar
Then it should be a direct swap. Just know that the odometer reading will change to the one you swap in.
Old Feb 4, 2011 | 03:02 PM
2one8's Avatar
yeah I messaged the seller about it but havent heard anything back. Just got my fingers crossed its close to mine lol
TIAN's Avatar
Hold The Line
You might also have to re-pin the plug. Years will also determine if they will be plug and play
Old Feb 4, 2011 | 04:25 PM
2one8's Avatar
Why re-pin the plug? And its out of a 2004 Sedan.
si_driver
Interior
Jul 25, 2015 09:22 AM
mushu
Jul 15, 2015 03:55 PM
driftsucky
Jul 15, 2015 12:38 PM
