help with my alinement results
Old Feb 17, 2011 | 09:21 PM
pqljohn's Avatar
ok, i installed my df210 spring 3 weeks ago, 2 weeks ago put on my new rims and tires, just get my alinement done today. after alinement i noticed that my steering wheel vibrate a little at 75+ mph. so i'm thinking maybe alinement is bad. btw im pretty sure they balanced wheel when i bought it. any input will be appreciate. attachment is alinement report sheet.
Old Feb 17, 2011 | 09:22 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
If that is your "After" alignment specs, you need to take it back and have them get your toe back in spec or say bye bye to your tires.
Old Feb 17, 2011 | 09:27 PM
pqljohn's Avatar
well, they said thats the closest they can get to factory spec. another anlinement shop?
Old Feb 17, 2011 | 10:25 PM
Deemo's Avatar
you might need camber kit w toe bolts.
Old Feb 17, 2011 | 10:35 PM
pqljohn's Avatar
sry, forgot to montion. i had both front & rear camber, and toe bolt.
Old Feb 17, 2011 | 10:59 PM
jibberjabbers's Avatar
All the "RED" items means the numbers are out of spec.
Check your suspensions, bushings and so on. They may all need to be replaced.
Also, check your compression rod bushings. Those things go out quick.
Also, the G's and 350z both have horrible suspensions right out of the dealership.
http://www.nissantireproblems.com/
Old Feb 17, 2011 | 11:18 PM
CandlestickPark's Avatar
ill Sedan
There is no reason they shouldn't be able to get your toe back in spec. I'm slammed and my alignment shop was able to get my toe back to 0.
Old Feb 17, 2011 | 11:22 PM
pqljohn's Avatar
thank you for all your input~ im going back tomorrow and ask them to get everything back into spec. ill update.
Thebaws11
Nov 30, 2016 12:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
9tray turbo
Sep 29, 2015 10:22 PM
