Test Pipes
Old Feb 25, 2011 | 10:54 AM
Sp33dY's Avatar
Question Test Pipes
Hey guys I really want to start on making a little more power out of my G I've had it for about 4 months now. My warranty is about to run out in April so I really wanted to start small and just build up from there first mod I want to do test pipes and the HKS replica exhaust. My question is how easy is it to install it I tired to find a DIY but couldn't find anything. If I take it to a shop how much should I be paying for a test pipe? Last night at a meet I asked a couple of guys BUT they all had G37s and they said the G37 is really hard to do without a lift, and if the G is the same way I should consider getting it done somewhere instead of just waisting my time.
Thank you all
Old Feb 25, 2011 | 12:14 PM
TofuProductions's Avatar
You don't need a DIY. it bolts right up. You can get it done without a lift but it's much easier with one.
Install time for me took about 1 hour.
Old Feb 25, 2011 | 12:20 PM
Sp33dY's Avatar
Is it easy to get the top ones off (closer to the headers) do I need extensions??
Old Feb 25, 2011 | 12:55 PM
i believed I used them just in case.
Old Feb 25, 2011 | 12:57 PM
Sp33dY's Avatar
WD40 needed huh?
Old Feb 25, 2011 | 01:18 PM
I just used PB Blaster.
Old Feb 25, 2011 | 01:45 PM
sTeadFasT96's Avatar
Please take a second to do a search as this topic has been discussed, but to answer your question, there is a video on youtube on how to install berk's HFC's which is the same exact procedure when dealing with any type of cat-replacement. Look that up. The rest of the exhaust is self explanatory and straight bolt on.
I used a deep socket, flex joint on one bolt (although I've had friends who didn't need it but for some reason I did), 20" extention, 6" extention, and a way to get A LOT of leverage.
Also PB blaster all the bolts and let them soak for half an hour. What I would do is to break all the bolts first before actually removing everything. Just make sure every bolt CAN be removed so you don't end up taking off one cat and having the other bolt giving you issues.
Old Feb 25, 2011 | 01:52 PM
cmesidewayz's Avatar
first off you need to decide what kind of test pipes or HFC's you want.
I would just get a jack stand kit to do the swap and to help you with future mods..
I just lifted the front of the car, took about an hour, very simple bolt on
Old Feb 25, 2011 | 01:58 PM
Sp33dY's Avatar
I want to get the Megan res TPs. Does anyone know if it will throw the CEL on????
magnetism80
Jan 27, 2016 12:57 PM
Atwork
Intake & Exhaust
Sep 20, 2015 03:36 AM
Albanian122
Sep 12, 2015 04:02 PM
Red G Coupe
Video Share
Sep 6, 2015 06:45 PM
TrillO.G.35
Sep 5, 2015 02:06 AM
