Stock G drives like a boat!
Old Mar 11, 2011 | 12:33 AM
nissin67's Avatar
I got my g (pure stock with sports+19's) and it drives like a boat!
I very much hate the boat-handling.
What's the first cheap mod I can do to make it drive better?
I'm thinking 350z htechs. Will sway bar help with the boat-feel especially acceleration/braking?
Hate stock.
Old Mar 11, 2011 | 01:06 AM
officerdbag's Avatar
sway bars number one, and stay away from h techs.
Old Mar 11, 2011 | 01:11 AM
nissin67's Avatar
Why what's wrong with them? Too little of a drop? Uneven drop?
Anything else I can do to anti-boat the g?
Old Mar 11, 2011 | 01:32 AM
Xet's Avatar
Xet
Nothing wrong with h-techs, although 350z h-techs are preferable. And yes do sways first, motordyne or hotchkis would be my first recommendation.
Old Mar 11, 2011 | 01:36 AM
doeboy's Avatar
I did the Z H-tech's and it did help a lil but I know I will be upgrading sway bars soon to stiffen everything up
Old Mar 11, 2011 | 01:52 AM
OGKushRob's Avatar
its not that bad bro, chill out. do some coilovers if its THAT bad to you. even though its not
Old Mar 11, 2011 | 04:44 AM
Blue Dream's Avatar
I drove ttrank's car solo
Sways + coilovers=problem solved
It will feel like a completely different car.
Old Mar 11, 2011 | 05:25 AM
Affalterbach's Avatar
What about the STILLEN sway bars? Someone recommended the Motordynes above.
Old Mar 11, 2011 | 08:02 AM
nissin67's Avatar
Does brand name sway bar matters if it is only for dd and not tracking?
Also, what's more important/effective: front or back?
Old Mar 11, 2011 | 08:14 AM
Cat's Avatar
Cat
Even just one or the other will make an impact both together is huge
Old Mar 11, 2011 | 08:45 AM
TofuProductions's Avatar
hotchkis sways with spl endlinkgs, gt spec chassis braces, maybe a strut bar in the front and rear, and some c/o's. GoKart status.
Old Mar 11, 2011 | 08:52 AM
nissin67's Avatar
Sounds exciting - should get front first or back?
Old Mar 11, 2011 | 08:58 AM
^They're sold in pairs. Put them on at the same time.
Otherwise go with the back first.
Old Mar 11, 2011 | 09:07 AM
Blue Dream's Avatar
IMHO I wouldn't get only one. The handling dynamics will be thrown off if you have one aftermarket bar and one stock bar. As T above stated, they are sold in pairs and there's a reason for that. Hard to go wrong with MD or Hotchkis, I have read on Driver of a couple sets of Stillens that have broken. Not a widespread issue though, more isolated incidents.
Old Mar 11, 2011 | 11:02 AM
JZ39's Avatar
Once you start in the handling department, you need to go all the way. Any one of the following will give you a slight improvement, all of them will make the car the way you want it.
Springs, adjustable shocks (better yet coilovers), sway bars, front strut brace.
If you lower, you will need camber and toe correction in back and I would recommend only lowering a bit in front since camber correction in the front is a much bigger/more expensive proposition.
Once you do this, you will never want to get into a stock car again. You get spoiled and when/if you get a new car (even if it has a "sports package") you will feel the need to change the suspension to something more responsive.
