K&N Drop-In Air Filter
Old Nov 11, 2004 | 02:39 PM
gspotter's Avatar
Anybody have any problems with this screwing up the MAF?
2004 Coupe 6MT / Caribbean Blue / Willow / Premium / Navi / Aero Package / Aero Kit / Splash Guards / Clear Corners / July 2004 build
Old Nov 11, 2004 | 04:18 PM
GRider35c's Avatar
Re: K&N Drop-In Air Filter
no sir! just dont OVERoil it...
Old Nov 11, 2004 | 05:40 PM
silvsurf's Avatar
almost a year with it. No problems.
Old Nov 11, 2004 | 06:04 PM
Diesel1's Avatar
Moderator
Nope! So far so good!
www.gsquad.org
Old Nov 11, 2004 | 08:17 PM
mvorion's Avatar
I had one, but it would cause my car to stall after rapid acceleration. As soon as the OEM filter went back in, the problem went away. Maybe my K&N was over oiled from the factory.
2004 G35C 6MT DG/G | Premium | Alum Pedals |Huper Optik 30/40/50 | Z-Tube | K&N Drop-In | Grounding Kit | Kenwood HU + NAV
Old Nov 12, 2004 | 11:19 AM
bocatrip's Avatar
An aquaintance of mine had one installed in his Q45. Right after the install, his car backfired and ran rough. I believe it was corrected over time. I am a believer of, if it's not broken, don't fix it. Therefore , no K&N for me.
2004 G35C/IvoryPearl/Graphite/5AT/Premium/Clear Bra
Old Nov 12, 2004 | 11:47 AM
KingOfJericho's Avatar
I have the Unlimited Tuning drop-in and it's GREAT... there is a noticable difference between even the K&N and the UT. I loved the K&N ans didn't have a single problem with it. I say go for it.
2004.5 Black on Black 6MT, Aero, Premium, Navi
"It's a celebration bitches" - Rick James
Old Nov 12, 2004 | 12:20 PM
SixFive's Avatar
So the drop in you have is noticable louder than the K&N?
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
K&N Drop In & Airbox Mod
10 Wire Hyper-Ground
Crawford Plenum (V4)
UR Crank Pulley
Hotchkis Sways (M/M)
Polk EX-3500 Tweeters/Shock Sensor/H-Liner
Old Nov 12, 2004 | 12:41 PM
it seems to suck in alot more air than the K&N because it doesn't have any filiment, just an extremely tightly woven stainless steel mesh. Hard to explain but it's really sweet.
Old Nov 12, 2004 | 02:45 PM
SixFive's Avatar
Sound like an expensive item tho? How much and how does steel mesh keep the intake air cleaner than a filiment with oil? Also I have the Z tube so I may not be interested in more noise - just better noise....very compelling item nevertheless
2003.5 DP 5AT Sedan
14.2 @ 97.18
Z-Tube
UR Crank Pulley
Old Nov 12, 2004 | 03:20 PM
gspotter's Avatar
Who sells those stainless steel filters? How much $$$$? I've never heard of them before.
Old Nov 12, 2004 | 08:52 PM
biscotti's Avatar
The intake from Blitz is also stainless steel. I would think think twice before installing though, the stainless steel filters are extremely high flow filters and how well they function as a filter for daily commuting is somewhat questionable.
Old Nov 13, 2004 | 09:57 AM
ozracer01's Avatar
The sound of a Drop in is not gonna be any different than stock, this is because you still have the resonators of the stock intake. Changing out the stock intake tube to a 350Z tube will definately create an "intake sound." I've had my drop in for about a year now, damn that reminds me to check up on that thing, i haven't cleaned it yet!
Old Nov 13, 2004 | 10:42 AM
derek's Avatar
From: Metropolitan South Farmington, not too far from the supercity we all know as Wilmot, NS
The ECU will compensate in seconds, and the car will then instantly thereafter run better. I put the K&N drop-in, then Ztube, then 5wire Grounding Gear kit, one at a time. Tried the ECU reset thing. And a JWT Pop later, but I took it off and went back to the K&N w/stock airbox cause I like the sound better.
I think the single best thing I did was the drop-in. Burbly sputter on rev-fall immediately disappeared, replaced with a very clean, well tuned note. Highly recommend the K&N. And as per the directions, you needn't clean it too often. Promise you'll be happy in making this change.
DB
KruZZe
Feb 27, 2023 05:04 PM
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
vamarris
Sep 26, 2015 12:56 PM
