Headlight cutting out
Old Mar 24, 2011 | 02:20 PM
DaddyinKC's Avatar
Now that it is dark in the morning I noticed on my way to work that when I hit a bump the drivers side headlight goes out. If the fog light is on, it stays on. If I turn off the headlights and turn them back on the headlight comes back on.
It appears to be a short somewhere, anyone have a suggestion for what may need to be replaced?
Old Mar 24, 2011 | 02:22 PM
theme718's Avatar
thats funny that same thing just started happening to me..
oneup's Avatar
Most likely a loose wire, or your ballast might be going out
Old Mar 24, 2011 | 02:35 PM
Xet's Avatar
Xet
Have you checked the plugs and everything yet?
Old Mar 24, 2011 | 02:53 PM
DaddyinKC's Avatar
Not yet. I am waiting for the weekend so I have some daylight since it is dark before and after work.
Old Mar 24, 2011 | 05:49 PM
EL-EE-ES's Avatar
Id say the ballast are going
Old Mar 24, 2011 | 05:51 PM
ilovez33's Avatar
Do you have aftermarket bulbs? Mine was doing the same thing and i changed my bulbs and presto its fixed.
Old Mar 24, 2011 | 06:04 PM
erklep's Avatar
+1 on the ballasts. i just so happen to have a pair for sale too! shoot me a PM if youre interested
Old Mar 24, 2011 | 06:46 PM
sTeadFasT96's Avatar
If I'm right there's something wrong with your igniter being loose and not being able to fully lock onto the bulb. I think this happens every so often to some people.
Old Mar 24, 2011 | 06:50 PM
pl_G35's Avatar
^Yep same thing happened to me....The plug on the bulb got loose after a while and would turn off the headlight every time I hit a big bump in the road.
Old Mar 25, 2011 | 09:53 AM
DaddyinKC's Avatar
I don't believe so, but I just bought the car a couple of months ago.
Old Mar 25, 2011 | 09:54 AM
DaddyinKC's Avatar
So, you just went in through the wheel area and tightened things?
Old Mar 25, 2011 | 09:57 AM
Project's Avatar
No its not your bulbs. Its the round connector that goes to the back. Over time they loosen up they have a spring wire to hold them onto the bulb tight.
Just push it back on and you will be fine. Takes two minutes. You can reach it from the engine bay.
Old Mar 25, 2011 | 11:50 AM
DaddyinKC's Avatar
Awesome, thanks....I can even do that in the dark!
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
