navi goes half way up then goes back down
Old Apr 2, 2011 | 01:06 PM
jrockstarr's Avatar
i searched this one and i see there was a tsb on this which does me no good now and not much else. is there any fix for this besides a whole new navigation system?
it gets halfway up, stops, and goes back down... help please
Old Apr 4, 2011 | 08:06 PM
lexx's Avatar
That happends to me too sometmes. I think if you lightly press it back toward the dash on the top part of the nav as it is rising it will raise all the way up. Then it won't happen again for a while. Not sure on a permenant fix though
Old Apr 4, 2011 | 11:23 PM
the_sedan's Avatar
its the motor assembly.
Old Apr 4, 2011 | 11:51 PM
anynigma's Avatar
Athens Blue G35 Coupe 6MT
the coupe, care to shed any specific details? I'll do a search for "navi motor assembly" tomorrow if its already covered and post here. This happens to me when the car is hot, esp in the summer. I apply light pressure to the top as it is rising, or lift it up. Also, it fixes itself sometimes if i press the up-down button on top a few times.
Old Apr 5, 2011 | 12:09 AM
jrockstarr's Avatar
it almost seems that it was getting stuck on something which makes the temp fix seem logical... worked for now but the motor seems fine.
do you have to replace the whole unit to fix this? or will i be able to keep doin the temp fix lol?
whats it cost to fix?
Old Apr 5, 2011 | 09:36 AM
anynigma's Avatar
As promised, I believe this is the issue: https://g35driver.com/forums/audio-v...few-weeks.html
i wonder if we can get the motor or motor harness replaced for free even if we're past 3 years of bumper to bumper warranty...Can I argue its a defect? (or part of my power train?! )
Old Apr 5, 2011 | 05:49 PM
azn pho life's Avatar
Mine sometimes goes all the way up and goes back down i just kind be like a spotter and hold it up while it goes up and it stays up. I haven't found a permanent fix but I can live with it.
Old Apr 5, 2011 | 07:08 PM
RgS03's Avatar
i had the same problem for a while and it pissed me off..figured out there was something really small stuck in there. i still cant get it out but it doesn't bother it any more
Old Apr 5, 2011 | 11:10 PM
the_sedan's Avatar
ill get the pn for it tomorrow at work. think of it like a window motor when you hit auto up and it goes up then halfway back down (anti-pinch activated).
Old Oct 25, 2012 | 04:14 PM
jrockstarr's Avatar
not to resurrect an old thread but the temporary fix has worn off. Did you ever get the part # or can you tell me what it should run to have repaired?
Old Oct 25, 2012 | 08:13 PM
Darkstar752's Avatar
What temporary fix did you do that lasts a year and a half?
Mine does this. I just firmly press down the button on top for a second or two and it comes up nearly everytime. If I just tap it, it usually stops halfway up.
Old Oct 26, 2012 | 08:46 AM
jrockstarr's Avatar
haha moving the screen back n forth till it found a position it liked. worked each way for a few months. now nothing works
Kng0fHrts
Sep 15, 2015 05:40 PM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
Frostbite91
Aug 2, 2015 04:59 PM
apintojr
Jul 23, 2015 10:52 AM
