Steering wheel crooked after installing sway bars
Old Apr 3, 2011 | 08:15 PM
wanagofaster's Avatar
I installed Motordyne Sway bars on my 03 coupe with oem endlinks today and when I went for a test drive I noticed that my steering wheel is not perfectly straight when going down a straight road. What on earth could have caused this. I dont even know how sway bars could affect your steering like that but I know that it wasnt like that before I installed them. (please dont move this to another page because id like for alot of people to read this and give me their input Thanks)
Old Apr 3, 2011 | 08:29 PM
WhosRich's Avatar
I don't think that the sway bars would cause any alignment issues since its just there to stiffen the chassis. Did you touch anything else besides the sway bars and end links?
Old Apr 3, 2011 | 08:57 PM
herrschaft's Avatar
Did you disconnect the steering knuckle at any time. Thats the only thing I could think of that may cause that.
Old Apr 3, 2011 | 09:07 PM
I disconected the rear lateral arm when I installed the rear sway bar. BUT I made sure that I marked where the camber washers were turned to and put it back together exactly the same way. I can see if the rear tire was way off it might go down the road crooked but the weird thing is that when I let off the steering wheel while the wheel is crooked the car goes perfectly straight.
Old Apr 4, 2011 | 12:38 AM
eNDleSs's Avatar
Get an alignment done.
Old Apr 4, 2011 | 03:56 AM
andrewstclair's Avatar
yea get an alignment if you didnt take off the steering knuckle then its the rear arm i messed up the alignment of one of the toe arms on mine and the wheel was like 45 degrees off after had to get an alignment
Old Apr 4, 2011 | 06:04 AM
So you guys think that me messing with that back wheel would have changed the angle of the steering wheel. Thanks for the input
Old Apr 4, 2011 | 06:07 AM
it sounds rediculous but like i said i did that before
Old Apr 4, 2011 | 01:14 PM
varelis617's Avatar
Alignment. I had a similar problem. After I aligned mine the before and after report showed my left rear toe was out of spec.
Old Apr 4, 2011 | 03:05 PM
I agree considering I didnt mess with anything else that had something to do with alignment. I did take some turns pretty hard when I was testing the sway bars but there is no way I couldve bent something to throw the alignment out.
Old Apr 4, 2011 | 08:27 PM
Just got a front end alignment and everything is perfect now, steering wheel is straight good as new. Very happy thanks guys
Old Apr 4, 2011 | 08:29 PM
WhosRich's Avatar
Glad to hear it. So it was because you disconnected the rear lateral arm.
Old Apr 4, 2011 | 08:42 PM
No I told the guy I disconected it and he said that that has nothing to do with the steering wheel being out of wack
jsimonk
Dec 22, 2023 03:49 PM
rezendvous420
May 31, 2020 01:26 PM
wuppiedog
Aug 7, 2015 11:16 AM
atk08
Jul 30, 2015 03:12 PM
itschuckster
Jul 25, 2015 08:07 AM
