ABS - SLIP and VDC lights all on ??
Old Apr 16, 2011 | 10:16 AM
swwessels's Avatar
just had the winter wheels/tires changed for the summer wheels/tires on my "04 MT coupe. Wheels are stock, tires are Michelins..problem is now - after change the dash indicators for ABS - SLIP and VDC all come on after about 30 seconds of travel. Amy ideas out there about what is the problem. This has never happened before with these seasonal changes of wheels/tires.
Steve W
Old Apr 16, 2011 | 10:22 AM
justin_2009's Avatar
I am usually not the one to say this but search it. The same thing happened to me and there is a big post about it.
Old Apr 16, 2011 | 11:08 AM
VeRDE35's Avatar
Search it it's ur camber shaft sensor most likely 03 and 04s all had a recall for this. Also, check your brake fluid
Old Apr 16, 2011 | 11:17 AM
icrazy2u's Avatar
Or you can drift like a beast.
Old Apr 16, 2011 | 01:06 PM
yeah i felt stupid because it ended up being my break fluid
Old Apr 16, 2011 | 06:56 PM
Blue Dream's Avatar
I drove ttrank's car solo
Never heard of this part on a G. Must be a custom piece.
Old Apr 16, 2011 | 10:01 PM
skiss12's Avatar
A similar situation hapened to my G however there was a buzzing noise that continued to make noise even after my G was turned off. In my case it turned out to be a VDC sensor. In your case from what i've read i would start with your brake fluid and if thats not it, even check your brake wear. The brake components on our vehicles seem to be directly linked to the trio of lights showing up.
Old Apr 16, 2011 | 10:28 PM
VeRDE35's Avatar
Meant cam shaft sensor iPhone must of auto spelled
Old Apr 17, 2011 | 03:26 AM
Oh_Really's Avatar
It could be your brake pads. I was driving fine and then all of a sudden, those exact lights came on and after I changed my rear brake pads, the lights went away.
Mry
Mar 3, 2023 01:03 AM
Luisgalvan33
Jul 19, 2018 08:16 PM
MsFitFern
Aug 9, 2015 02:58 PM
Luisgalvan33
Jul 28, 2015 05:37 PM
Wayne9011
Jul 27, 2015 11:25 AM
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
